Home » Archived » BIRT » Setting Table invisible if no records found
Setting Table invisible if no records found [message #45260] Mon, 13 June 2005 07:22
Originally posted by: juergen.schwarz.gefasoft.de
I want to make a table invisible if no records are found in the dataset
to which the table is bound.
In the BIRT Eclipse plugin I tried to set the appropriate property
"Visibility" but my problem is that I don't know how to get a record
count for the dataset.
Any ideas?
Juergen
Previous Topic:Image insertion(URI/Embedded) gives Errors
Next Topic:API document about chart engine
Current Time: Fri Nov 14 07:32:46 EST 2025
Powered by FUDForum. Page generated in 0.03831 seconds
