Home » Modeling » OCL » constraints with Set...
constraints with Set... [message #45244] Wed, 28 November 2007 14:25 Go to next message
Originally posted by: asma.charfi.com
to verify the direction of a port, this constraint works perfectly
let port:
P::Port=self.getStereotypeApplication(self.getAppliedStereot ype('P::Port')).oclAsType(P::Port)
in port.direction=P::DirectionKind::out
now I want to verify that my component contains only out Ports (its
direction=out) I write this constraint:
self.ownedPort.getAppliedStereotypes()->forAll(s| let ports : Set( P::Port )
=self.getStereotypeApplication(s).oclAsType(Set ( P::Port )) in
ports->forAll(p|p.direction=P::DirectionKind::out)
it return illegal operation signature: (Set(OclType))
what is the problem? thank you a lot
Asma
Re: constraints with Set... [message #45344 is a reply to message #45244] Wed, 28 November 2007 08:52 Go to previous messageGo to next message
Hi, Asma,
The oclAsType() cast operation and oclIsKindOf() conformance testing
operation only apply to instances of OclAny, which OCL's collections are
not. That is to say, you cannot cast collections.
Besides, you cannot ask the component for the stereotype applications of its
owned ports.
Does this work?
self.ownedPort->forAll(
let p : P::Port = getStereotypeApplication(
getAppliedStereotype('P::Port')).oclAsType(P::Port) in
p.direction = P::DirectionKind::out)
Again, using the UML environment this would be tidier:
not extension_Port.oclIsUndefined() and
extension_Port.direction = P::DirectionKind::out)
HTH,
Christian
charfi asma wrote:
> let port:
> ) =self.getStereotypeApplication(s).oclAsType(Set ( P::Port )) in
> Asma
Re: constraints with Set... [message #45393 is a reply to message #45344] Wed, 28 November 2007 21:58 Go to previous messageGo to next message
Thank you Christian! it works but only in console. I think I have problem in
choosing context :-(
when I chose M2 and UML in the console's action bar this constraint works
perfectly .
self.ownedPort->forAll(let p : Gaspard::FlowPort =
getStereotypeApplication(getAppliedStereotype('Gaspard::Flow Port')).oclAsType(Gaspard::FlowPort)
in p.direction = Gaspard::DirectionKind::out) // when I click on
component whose ports are stereotypsed Port
Now, I want to validate model using my plugin:
when I put stereotype as context and add base_Component and extension_Port
to my constraint it works:
the constraint is " self.base_Component.ownedPort->forAll(let p : P::Port =
getStereotypeApplication(getAppliedStereotype('P::Port')).oc lAsType(P::Port)
in p.extension_Port.direction = P::DirectionKind::out)
-------------------------------------------------using UML
environnement:M1-------------------------------------------- ----
ocl2 = org.eclipse.ocl.uml.OCL.newInstance();
oclHelper = ocl2.createOCLHelper();
stereotype = element.getAppliedStereotypes().get(0);
oclHelper.setContext(stereotype);
oclInv = (Constraint)
oclHelper.createInvariant(stereotype.getOwnedRules().get(i). getSpecification().stringValue());
resultat=ocl2.check(element,oclInv);
My problem is, , I get errors when I put a metaclass as context (I do it to
use M2 level and this to avoid using extension_end and base_component caus
my profile is exported from magicdraw):
the constraint is: self.ownedPort->forAll(let p : Gaspard::FlowPort =
the error is : ERROR in (enumerationOrClassLiteralExpCS): (Unknown type ([P,
Port]))
environnement:M2-------------------------------------------- ----
Classifier metaclass=(Classifier)
umlMetamodel.getOwnedType(stereotype.eClass().getName());
//metaclass=Stereotype
oclHelper.setContext(metaclass);
when I use console with UML and M2 it works but when I use my plugin it did
not work? did you have any explications?
I tried to change the metaclass, I use Component (metaclass of selected
element) instead but I got the same error.
In UML M2 console's level, which context is used ?(cause the constraint was
parsed and evaluated perfectly in the console).
thank you
ASMA
"Christian W. Damus" <cdamus@ca.ibm.com> a
Re: constraints with Set... [message #45423 is a reply to message #45344] Wed, 28 November 2007 22:07 Go to previous message
In the error I used P and Port, and in the constraint I used Gspard and
FlowPort they are the same:
Rectification: P=Gaspard and Port=FlowPort
thank you ;-)
asma
Previous Topic:[Announce] MDT OCL 1.2.0 I200711281424 is available
Next Topic:Re: using the Type: MyProfile::MyStereotype
Current Time: Sun Nov 09 08:29:56 EST 2025
Powered by FUDForum. Page generated in 0.04460 seconds
