Home » Archived » XML Schema Definition (XSD) » Retrieving user information
Retrieving user information [message #45221] Fri, 21 May 2004 17:57 Go to next message
Ed,
I am trying to retrieve the content of <xs:documentation> nodes in my XSD
document. The logic I am trying is shown below but it does not return the
content. I am unsure if Element.getNodeValue() is really the correct method
to retrieve the content of the document node but I do not see any other
methods via the Element API. Also, examining all the Annotation contents
while running my code in debug has not given me any ideas. Do you have any
suggestions?
XSDAnnotation annotation = entity.getAnnotation();
if(annotation != null){
final Iterator userInfos =
annotation.getUserInformation().iterator();
while(userInfos.hasNext() ){
final Element userInfo = (Element)userInfos.next();
final String value = userInfo.getNodeValue();
if (value != null) {
return value;
Thanks in advance,
Dennis Fuglsang
Re: Retrieving user information [message #45319 is a reply to message #45221] Tue, 25 May 2004 06:32 Go to previous messageGo to next message
Dennis,
According to the Javadoc, Element.getNodeValue will always give you null. I
think you want to access the children, i.e., getFirstChild followed by
getNextSibling, which will yield the text nodes and other child nodes.
Dennis Fuglsang wrote:
> Ed,
> suggestions?
> return value;
> Thanks in advance,
> Dennis Fuglsang
Re: Retrieving user information [message #45409 is a reply to message #45319] Tue, 25 May 2004 10:12 Go to previous message
Thanks Ed.
I also found some example code in the org.apache.xerces.util.DOMUtil class
that does what you are indicating.
public static String getChildText(Node node) {
// is there anything to do?
if (node == null) {
return null;
// concatenate children text
StringBuffer str = new StringBuffer();
Node child = node.getFirstChild();
while (child != null) {
short type = child.getNodeType();
if (type == Node.TEXT_NODE) {
str.append(child.getNodeValue());
else if (type == Node.CDATA_SECTION_NODE) {
str.append(getChildText(child));
child = child.getNextSibling();
// return text value
return str.toString();
} // getChildText(Node):String
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:40B320A2.2C6B50B4@ca.ibm.com...
> Dennis,
I
> > Ed,
XSD
the
method
contents
any
> > suggestions?
> > return value;
> > Thanks in advance,
> > Dennis Fuglsang
Re: Retrieving user information [message #587428 is a reply to message #45221] Tue, 25 May 2004 06:32 Go to previous message
Dennis,
> Ed,
> suggestions?
> return value;
> Thanks in advance,
> Dennis Fuglsang
Re: Retrieving user information [message #587478 is a reply to message #45319] Tue, 25 May 2004 10:12 Go to previous message
Thanks Ed.
if (node == null) {
return null;
> Dennis,
I
> > Ed,
XSD
the
method
contents
any
> > suggestions?
> > return value;
> > Thanks in advance,
> > Dennis Fuglsang
Previous Topic:How to parse a schema from an InputStream
Next Topic:NPE during schema validation
Current Time: Thu Nov 27 21:44:01 EST 2025
Powered by FUDForum. Page generated in 0.05911 seconds
