Home » Archived » M2M (model-to-model transformation) » [ATL] conflict between metamodel and MOF
[ATL] conflict between metamodel and MOF [message #45205] Fri, 08 June 2007 05:59 Go to next message
Originally posted by: djodjo91.free.fr
i have a little problem of name conflict between my metamodel and mof
attribute. In my metamodel i have a templateSignature which has
ownedTemplateParameter attributes. The problem is when i try to do
something like :
templateSignature.ownedTemplateParameter->append(templateParameter)
i have an error in my transfo "ERROR : could not find operation append on
MOF!EClass...".
A solution would be to change the name attribute in my metamodel (for
example ownedTemplateParameter would be ownedTemplateParam) but i was
wondering if there could be a way to force the use of my metamodel
attribute ?
I hope people who will read my post will understand what i mean, sorry for
my bad english.
Re: [ATL] conflict between metamodel and MOF [message #45265 is a reply to message #45205] Fri, 08 June 2007 08:20 Go to previous messageGo to next message
Originally posted by: rchevrel.sodius.com
--------------070102060702050201000303
Hi Jonathan,
I am not sure but try to use double quote like:
templateSignature."ownedTemplateParameter"->append(templateParameter)
*R
Re: [ATL] conflict between metamodel and MOF [message #45477 is a reply to message #45265] Mon, 11 June 2007 03:29 Go to previous message
hi,
first thank you for your answer Regis. But in fact it was another mistake,
i was calling a rule which doesn't have return element, and i was trying
to do an affectation.
ex : dst.ownedTemplateParameter ->
append(thisModule.createCPPTemplateParameter(a,b)) and
createCPPTemplateParameter(a,b) didn't return anything... :)
regards,
jonathan
Previous Topic:[ATL] Cross references
Next Topic:Simultanious loading of two collections which are brances of the same tree
Current Time: Sat Nov 08 20:01:52 EST 2025
Powered by FUDForum. Page generated in 0.03691 seconds
