Home » Modeling » M2T (model-to-text transformation) » Java class as source
Java class as source [message #45200] Wed, 07 May 2008 15:48 Go to next message
I want to create a set of decorator classes for a set of existing
interfaces. Most of the methods are pass through methods. For instance,
public class MyDecoratorImpl extends EObjectImpl{
private MyDecoratedObject decorated;
public Foo getFoo(){
decorated.getFoo();
I want to walk the methods of the input class and generate the output
EObject classes. The problem is the class loading. I cannot simply call
Class.forName("com.foo.MyDecoratedObject") from within the template or
within a custom tag library.
Any thoughts?
- Ricker
Re: Java class as source [message #45234 is a reply to message #45200] Thu, 08 May 2008 13:11 Go to previous messageGo to next message
Ricker:
Getting JET to read on existing meta-model (such as the Java reflective
APIs) involves two things:
1) creating a set of XPath 'inspectors' that let the XPath engine understand
model elements in terms of the XPath infoset.
2) (optional) if you want to such meta-models from the Eclipse workspace,
you must also create a 'model loader'.
JET has extension points for both.
I have an example of these as an example in CVS. Co-incidentally, the
example my do what you want. The 'loader' loads a .java file by creating an
JDT Abstract Syntax Tree (AST). The inspector traverses the tree.
Details on how to check out the example are found in bug 227819
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=227819).
Working from an AST allow you to do what you want. If it does, I'd
appreciate feedback on the loader/inspector. It would be nice to incorprate
it into JET proper one day.
Paul
"Jeffrey Ricker" <ricker@jeffreyricker.com> wrote in message
news:fvt122$dt$1@build.eclipse.org...
> decorated.getFoo();
> Any thoughts?
> - Ricker
Re: Java class as source [message #45264 is a reply to message #45200] Fri, 09 May 2008 07:56 Go to previous message
Hey Jeffrey,
when I click on a java file, and do open with... I can select
"Java Model Editor" somewhere down the list. It seems like EMF provides a java
ecore model, that makes it possible to inspect java classes via emf. As jet can
do emf this would maybe be an elegant (but possibly slower) way to solve your
problem?
Felix
Previous Topic:ensure import programatically
Next Topic:run ant task passing variables
Current Time: Thu Nov 06 12:55:22 EST 2025
Powered by FUDForum. Page generated in 0.04552 seconds
