Home » Archived » OHF » Test12049 XDS.b Submit a document error
Test12049 XDS.b Submit a document error [message #45196] Wed, 06 August 2008 23:31 Go to next message
Originally posted by: 322zx.163.com
org.eclipse.ohf.ihe.xds.source.test.mesa-11746 was successful
but Test12049 was failed:
Errors:
[DEBUG][DeploymentEngine.java:465] Adding new module
[DEBUG][ProjectResourceBundle.java:70]
org.apache.axis2.i18n.resource::handleGetObject(deployeingmo dule)
[INFO ][ModuleDeployer.java:72] Deploying module: addressing-1.3
[DEBUG][AxisService.java:716] mapActionToOperation: Mapping Action to
Operation: action: anonRobustOp; operation:
org.apache.axis2.description.RobustOutOnlyAxisOperation@1478a43
Operation: action: urn:anonRobustOp; operation:
Operation: action: anonOutonlyOp; operation:
org.apache.axis2.description.OutOnlyAxisOperation@1372656
Operation: action: urn:anonOutonlyOp; operation:
Operation: action: anonOutInOp; operation:
org.apache.axis2.description.OutInAxisOperation@1b6101e
Operation: action: urn:anonOutInOp; operation:
[DEBUG][AbstractXDSSoapClient.java:113] Beginning XDS SOAP Send
org.apache.axiom.om.OMException: com.ctc.wstx.exc.WstxParsingException:
Undeclared namespace prefix "ihe"
at [row,col {unknown-source}]: [2,42]
org.apache.axiom.om.impl.builder.StAXOMBuilder.next(StAXOMBu ilder.java:239)
org.apache.axiom.om.impl.llom.OMDocumentImpl.getOMDocumentEl ement(OMDocumentImpl.java:130)
org.apache.axiom.om.impl.builder.StAXOMBuilder.getDocumentEl ement(StAXOMBuilder.java:359)
at org.apache.axis2.util.XMLUtils.toOM(XMLUtils.java:533)
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:116)
at org.eclipse.ohf.ihe.xds.source.B_Source.submit(B_Source.java :166)
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa12049_Option1.t est(Mesa12049_Option1.java:106)
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa12049_Option1.m ain(Mesa12049_Option1.java:124)
Caused by: com.ctc.wstx.exc.WstxParsingException: Undeclared namespace
prefix "ihe"
com.ctc.wstx.sr.StreamScanner.constructWfcException(StreamSc anner.java:605)
at com.ctc.wstx.sr.StreamScanner.throwParseError(StreamScanner. java:467)
com.ctc.wstx.sr.NsInputElementStack.resolveAndValidateElemen t(NsInputElementStack.java:368)
com.ctc.wstx.sr.BasicStreamReader.handleStartElem(BasicStrea mReader.java:2945)
com.ctc.wstx.sr.BasicStreamReader.handleRootElem(BasicStream Reader.java:2093)
com.ctc.wstx.sr.BasicStreamReader.nextFromProlog(BasicStream Reader.java:2073)
at com.ctc.wstx.sr.BasicStreamReader.next(BasicStreamReader.jav a:1069)
org.apache.axiom.om.impl.builder.StAXOMBuilder.next(StAXOMBu ilder.java:153)
... 7 more
Re: Test12049 XDS.b Submit a document error [message #45259 is a reply to message #45196] Thu, 07 August 2008 12:19 Go to previous messageGo to next message
Please post more lines of the log file. Also, what versions of OHF and
Eclipse are you using?
-Matt
> Errors:
> at
> at
> at
> at
> at
> at
> prefix "ihe"
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
Re: Test12049 XDS.b Submit a document error [message #45293 is a reply to message #45259] Thu, 07 August 2008 20:52 Go to previous message
I used IHE 2.0,the code downed form the CVS.
All the errors are here:
Eishay comment: output file is
D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.xds.so urce\resources\logs\source.log
with append attribute = true
[DEBUG][B_SourceMesaTest.java:43] ***************** SUBMIT TEST
[DEBUG][B_SourceMesaTest.java:44] 2008/8/8 8:48:51
[DEBUG][Mesa12049_Option1.java:60] BEGIN MESA 12049 option 1
[DEBUG][Mesa12049_Option1.java:64] Adding input document, and metadata.
[DEBUG][Document.java:109] Created new Document from
File=D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.x ds.source\.\resources\sample_files\test1\input.xml
Descriptor=CDA-R2!text/xml MimeType=text/xml
[DEBUG][SubmitTransactionData.java:257] loadDocumentWithMetadata() adding
D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.xds.so urce\resources\sample_files\test1\input.xml
[DEBUG][InputStreamDocumentEntryExtractor.java:62] Loading MetadataPackage.
[DEBUG][InputStreamDocumentEntryExtractor.java:68] Loading Resources.
[DEBUG][InputStreamDocumentEntryExtractor.java:79] Creating DocumentEntry
metadata with object from InputStream java.io.FileInputStream@19b5393
[DEBUG][SubmitTransactionData.java:278] DocumentEntry entryUUID generated.
[DEBUG][SubmitTransactionData.java:299] Document metadata loaded. Current
DocumentEntry entryUUID: urn:uuid:9de00e1e-3dda-7436-b82b-001d7dab48a4.
[DEBUG][SubmitTransactionData.java:304] loadDocumentWithMetadata()
document was successfully added.
[DEBUG][Mesa12049_Option1.java:74] Saving docEntryUUId for replaceTEst
[DEBUG][SubmitTransactionData.java:587] DocumentEntry metadata found for
[DEBUG][Mesa12049_Option1.java:83] Done setting documentEntry metadata
for: org.eclipse.ohf.ihe.xds.metadata.impl.DocumentEntryTypeImpl@4e79f1
(availabilityStatus: <unset>, creationTime: 20060614, entryUUID:
urn:uuid:9de00e1e-3dda-7436-b82b-001d7dab48a4, hash: null, languageCode:
en-US, mimeType: text/xml, repositoryUniqueId: null, serviceStartTime:
null, serviceStopTime: null, size: null, uniqueId:
1.2.3.4.103029050023315117.1218156534656.1, uri: null, existing: <unset>)
[DEBUG][Mesa12049_Option1.java:87] Applying Submission Set Metadata to the
Submission.
[DEBUG][InputStreamSubmissionSetExtractor.java:67] Loading MetadataPackage.
[DEBUG][InputStreamSubmissionSetExtractor.java:73] Loading Resources.
[DEBUG][InputStreamSubmissionSetExtractor.java:84] Creating SubmissionSet
metadata with object from InputStream java.io.FileInputStream@5a9de6
[DEBUG][SubmitTransactionData.java:943] Previous Submission entryUUID:
urn:uuid:9ddfd4bc-3dda-7436-3123-001d7dab48a4.
[DEBUG][SubmitTransactionData.java:954] Submission Set metadata loaded.
Current Submission entryUUID:
[DEBUG][Mesa12049_Option1.java:105] Submitting Document.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:115] Setting attributes on
the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:121] Setting Description on
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:127] Setting Name on the
Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:133] Setting Slots on the
Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:139] Setting
Classifications on the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:145] Setting External
Identifiers on the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:401] No Submission Set
Associated Documents.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:429] No Submission Set
Associated Folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:343] All
submission set metadata added.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:117] Adding
document metadata to submission set. There are 1 documents to add.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:113] Setting attributes on
the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:119] Setting Name on the
Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:125] Setting Description on
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:132] Setting Slots on the
Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:138] Setting
Classifications on the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:144] Setting
ExternalIdentifiers on the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:197] No parentDocumentID
for urn:uuid:9de00e1e-3dda-7436-b82b-001d7dab48a4.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:324] All
document metadata added to submission set.
[INFO ][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.java:127 ]
Submission set contains no folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:142]
Verifying Submission Set associated documents and associated folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:431]
Verifying associated documents
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:480] Number
of "forgotten" submission set existing associated documents: 0
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:485]
Verifying associated folders
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:526] Number
of "forgotten" submission set existing associated folders: 0
[DEBUG][Loader.java:132] Trying to find
[org/apache/axis2/deployment/axis2_default.xml] using
sun.misc.Launcher$AppClassLoader@82ba41 class loader.
[DEBUG][Phase.java:96] Handler RequestURIBasedDispatcher added to Phase
Transport
[DEBUG][Phase.java:96] Handler SOAPActionBasedDispatcher added to Phase
Transport
[DEBUG][Phase.java:96] Handler AddressingBasedDispatcher added to Phase
Addressing
Dispatch
Dispatch
[DEBUG][Phase.java:96] Handler RequestURIOperationDispatcher added to
Phase Dispatch
[DEBUG][Phase.java:96] Handler SOAPMessageBodyBasedDispatcher added to
Phase Dispatch
[DEBUG][Phase.java:96] Handler HTTPLocationBasedDispatcher added to Phase
Dispatch
Addressing
Dispatch
Dispatch
Phase Dispatch
Phase Dispatch
Dispatch
[INFO ][Utils.java:191] Created temporary file :
C:\DOCUME~1\postgres\LOCALS~1\Temp\_axis2\axis229051addressi ng-1.3.jar
[DEBUG][ProjectResourceBundle.java:236]
getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,nu ll,...)
[DEBUG][ProjectResourceBundle.java:412] loadBundle: Ignoring
MissingResourceException: Can't find bundle for base name
org.apache.axis2.resource, locale zh_CN
[DEBUG][ProjectResourceBundle.java:289] Created
org.apache.axis2.i18n.resource, linked to parent null
org.apache.axis2.i18n.resource::handleGetObject(addingnewmod ule)
C:\DOCUME~1\postgres\LOCALS~1\Temp\_axis2\axis229052addressi ng-1.3.mar
prefix "ihe"
... 7 more
Re: Test12049 XDS.b Submit a document error [message #586533 is a reply to message #45196] Thu, 07 August 2008 12:19 Go to previous message
-Matt
> Errors:
> at
> at
> at
> at
> at
> at
> prefix "ihe"
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
Re: Test12049 XDS.b Submit a document error [message #586552 is a reply to message #45259] Thu, 07 August 2008 20:52 Go to previous message
Submission.
Registry Package.
Registry Package.
Associated Folders.
Extrinsic Object.
Extrinsic Object.
Transport
Transport
Addressing
Dispatch
Dispatch
Phase Dispatch
Phase Dispatch
Dispatch
Addressing
Dispatch
Dispatch
Phase Dispatch
Phase Dispatch
Dispatch
prefix "ihe"
... 7 more
Previous Topic:Test12049 XDS.b Submit a document error
Next Topic:Xds.b submit tests have the same errors
Current Time: Sat Nov 08 03:57:45 EST 2025
Powered by FUDForum. Page generated in 0.03837 seconds
