Home » Archived » BIRT » Script Datasources and Java packages
Script Datasources and Java packages [message #45193] Mon, 13 June 2005 03:44 Go to next message
Hi all
I have a script data source where i try to access a Java Class
on dataset's open method:
<snip>
cf = new Packages.gr.osmosis.report.data.ContactListFactory();
</snip>
unfortunately i get the error message:
<snip>
There are errors on the report page:
Error1:Invalid Javascript expression. Source: DataSet:setScript.open, line:
0, Expression:
function_prefix_1118645822385();function
function_prefix_1118645822385(){count = 0;
c = fc.createContactList();}
Script engine error: TypeError: [JavaPackage
gr.osmosis.report.data.ContactListFactory] is not a function.
(DataSet:setScript.open#1)
</snip>
my report lives in the same project with those java classes.
Any hint?
regards
stavros
Stavros Kounis Osmosis networks & consulting
http://tools.osmosis.gr/blog http://www.osmosis.gr
Re: Script Datasources and Java packages [message #53455 is a reply to message #45193] Tue, 05 July 2005 06:36 Go to previous messageGo to next message
The WebbApp preview plugin couldn
Re: Script Datasources and Java packages [message #53924 is a reply to message #45193] Wed, 06 July 2005 03:30 Go to previous messageGo to next message
Originally posted by: Dirk.Ecker.viadee.de
A solution is explained in:
http://tools.osmosis.gr/blog/archives/2005/06/birt_and_objec t.html
Excerpt:
Preview
Here is a litle problem when we are working in design mode. Report's
script must be able to find our java classes (Contact.java,
ContactListFactory.java). Report designer use BIRT's web-app viewer to
render (preview) the report. But this WEB-APP does not know where to look
for our java classes. This web-app exist as an eclipse plug-in.
for example:
C:\JProgramFiles\eclipse-SDK-3.0.2-win32\eclipse\plugins\org .eclipse.birt.report.viewer_1.0.0
We have to put our classes in a "classes" folder in this web-app. To do
this create a "classes" folder at birt\web-inf.
Build Contact.java and ContactListFactory.java and put the produced .class
files in this "classes" folder.
Dont forget to create inside "classes" folder the directory structure that
match the package name.
for example:
if you just copy paste the code from this post then you must have a path
like:
C:\JProgramFiles\eclipse-SDK-3.0.2-win32\eclipse\plugins\org .eclipse.birt.report.viewer_1.0.0\birt\WEB-INF\classes\gr\os mosis\report\data
Now you can preview your report selecting "Preview" tab.
Dirk
Re: Script Datasources and Java packages [message #58363 is a reply to message #53924] Thu, 14 July 2005 11:25 Go to previous message
Originally posted by: tstuchel.yahoo.com
I attempted this solution and was unsuccessful. I placed the full contents
of the /classes directory of my Java project into the directory (for me):
C:\java\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0 \birt\WEB-INF
such that I had:
C:\java\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0 \birt\WEB-INF\classes\[project
class structure]
and I still get the "is not a function" to the default constructor of my
class. The class has only one method, the constructor, which takes no
parameters.
Is there something else that I am missing? I get a pop-up error with the "is
not a function" error whenever I use the Data Explorer, even when I edit the
code for the Data Source or the Data Set that uses it (that is, without
actually running a preview).
"Dirk Ecker" <Dirk.Ecker@viadee.de> wrote in message
news:abb725c7507254da5338bebb465c4cba$1@www.eclipse.org...
> Excerpt:
> Preview
> for example:
> for example:
> like:
> Dirk
Previous Topic:BIRT Installation Problem Unable To instantiate editor
Next Topic:Migrating our reports to BIRT
Current Time: Wed Nov 19 19:13:45 EST 2025
Powered by FUDForum. Page generated in 0.03701 seconds
