Home » Archived » Visual Editor (VE) » Layout question
Layout question [message #45172] Wed, 30 June 2004 18:47 Go to next message
Is it possible to set a custom Layout manager with the latest version of
VE ?
I am thinking about the Vertical flow layout from jBuilder...
OR
Re: Layout question [message #45294 is a reply to message #45172] Wed, 30 June 2004 22:46 Go to previous message
Yes, it's possible to add a custom layout manager to the VE, if the
layout class has a no argument constructor. It is necessary to define
an Eclipse plug-in to contribute to the layout extension point and
define the necessary overrides.
Information about doing this is available in this posting from the
ve-dev mailing list:
http://dev.eclipse.org/mhonarc/lists/ve-dev/msg00280.html
(use the newsgroup login to access the archives)
I'm eventually going to put these instructions together as an article in
the Extending the Visual Editor series, so any feedback is welcome.
- Jeff
> VE ?
> OR
Re: Layout question [message #593314 is a reply to message #45172] Wed, 30 June 2004 22:46 Go to previous message
- Jeff
> VE ?
> OR
Previous Topic:labels aren't declared as fields anymore
Next Topic:Which VE, EMF GEF versions for E 2.1.3
Current Time: Fri Nov 14 00:58:59 EST 2025
Powered by FUDForum. Page generated in 0.03349 seconds
