Home » Eclipse Projects » Mylyn » custom bugzilla fields with mylyn?
custom bugzilla fields with mylyn? [message #45161] Sun, 09 March 2008 15:55 Go to next message
Is it posible to edit custom bugzilla fields with mylyn?
I know there is limited support for custom fields in bugzilla. The bugzilla
I use is an extended version of bugzilla 3.0 with custom fields. Because I'm
only a user to this bugzilla I don't know if it uses the custom fields from
bugzilla or if it is a modified version. Though I will try to get the
information.
Thanks, Tobias
Re: custom bugzilla fields with mylyn? [message #45254 is a reply to message #45161] Mon, 10 March 2008 15:02 Go to previous messageGo to next message
> information.
> Thanks, Tobias
Hi Tobias,
as far as I know you need to have administration rights.
Mylyn only supports the use of custom fields and not the definition.
Here the text from the administration page of bugzilla 3.1.2
Bugzilla lets you define fields which are not implemented by default, based on
your local and specific requirements. These fields can then be used as any other
field, meaning that you can set them in bugs and run any search involving them.
Before creating new fields, keep in mind that too many fields may make the user
interface more complex and harder to use. Be sure you have investigated other
ways to satisfy your needs before doing this.
Frank
Re: custom bugzilla fields with mylyn? [message #45311 is a reply to message #45161] Tue, 11 March 2008 14:13 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
Tobias,
If you're wondering if Mylyn's Bugzilla Connector support custom fields,
it is not yet supported but will be in Mylyn 3.0 (Jun 30).
To determine if the repository in question is making use of custom
fields you can open your browser to:
<your-repository-url>/show_bug.cgi?id=1&ctype=xml
The resulting configuration information will show which fields are
custom (I believe they start with cf_ but perhaps Frank can confirm this).
-Rob
> information.
> Thanks, Tobias
Re: custom bugzilla fields with mylyn? [message #45398 is a reply to message #45311] Wed, 12 March 2008 00:42 Go to previous message
Robert Elves <rob.elves@eclipse.org> wrote:
> Tobias,
Yes all custom fields must start with cf_. When you create a field that prefix
get addee if not pressent.
> -Rob
>> information.
>> Thanks, Tobias
Re: custom bugzilla fields with mylyn? [message #588436 is a reply to message #45161] Mon, 10 March 2008 15:02 Go to previous message
> information.
> Thanks, Tobias
Hi Tobias,
Frank
Re: custom bugzilla fields with mylyn? [message #588457 is a reply to message #45161] Tue, 11 March 2008 14:13 Go to previous message
Tobias,
-Rob
> information.
> Thanks, Tobias
Re: custom bugzilla fields with mylyn? [message #588485 is a reply to message #45311] Wed, 12 March 2008 00:42 Go to previous message
> Tobias,
> -Rob
>> information.
>> Thanks, Tobias
Previous Topic:Can you remove "Unmatched Tasks"?
Next Topic:Mylyn and Navigator View
Current Time: Sun Nov 16 11:25:54 EST 2025
Powered by FUDForum. Page generated in 0.04278 seconds
