Home » Eclipse Projects » SWTBot » Key Press: Enter
Key Press: Enter [message #45050] Wed, 22 July 2009 19:59 Go to next message
Ketan,
I have been writing a test case with SWTBot and one of the requirements is
to type a keyboard shortcut CTRL + SHFT + Enter. I can successfully press
the first two keys, but am unable to press the Enter key because in the
SWT class there is not equivalent for SWT.ENTER. Below are a few lines of
code I have written. Any Suggestions on how I can test the pressing of the
Enter key?
KeyStroke ctrl = KeyStroke.getInstance(SWT.CTRL, 0);
KeyStroke shift = KeyStroke.getInstance(SWT.SHIFT, 0);
//KeyStroke ret = KeyStroke.getInstance(0, SWT.???);
bot.sleep(2000);
//k.pressShortcut(ctrl, shift, ret);
Mike
Re: Key Press: Enter [message #45062 is a reply to message #45050] Thu, 23 July 2009 00:18 Go to previous messageGo to next message
Keystrokes.CR and Keystrokes.LF is what you're looking for.
Some more keystrokes here:
http://github.com/ketan/swtbot/blob/9f2a3beb6dc00e8827fe127e ec589a80bcdfe6b6/org.eclipse.swtbot.swt.finder/src/org/eclip se/swtbot/swt/finder/keyboard/Keystrokes.java
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 23/7/09 05:29, Michael Wiederhold wrote:
> Ketan,
> is to type a keyboard shortcut CTRL + SHFT + Enter. I can successfully
> press the first two keys, but am unable to press the Enter key because
> in the SWT class there is not equivalent for SWT.ENTER. Below are a few
> lines of code I have written. Any Suggestions on how I can test the
> pressing of the Enter key?
> bot.sleep(2000);
> Mike
Re: Key Press: Enter [message #485767 is a reply to message #45062] Mon, 14 September 2009 17:29 Go to previous messageGo to next message
Hi, I have a SWTBot test where I open the editor, type in text, and then save the file. The data ends up on one single line. I would like to insert a "press Enter" after each text line in the loop sequence so I end up with 10 records in the file.
I have tried incorporating the suggestion here, but can't seem to get it right. It completely ignores the keystrokes. Could someone please let me know what I'm missing?
SWTBotEditor edit = bot.editorByTitle(dataset);
SWTBotEclipseEditor textEditor = edit.toTextEditor();
KeyStroke enter = KeyStroke.getInstance(SWT.CR, 0);
KeyStroke lf = KeyStroke.getInstance(SWT.LF, 0);
for(int l=1; l<11; l++) {
textEditor.typeText("test line " + l + enter + lf);
bot.sleep(5000);
bot.editorByTitle(dataset).saveAndClose();
Michelle
Re: Key Press: Enter [message #485787 is a reply to message #485767] Mon, 14 September 2009 22:06 Go to previous messageGo to next message
That is incorrect usage of the api. The correct usage would be:
textEditor.typeText("test line " + l + "\n");
Ketan
> bot.sleep(5000);
> Michelle
Re: Key Press: Enter [message #485920 is a reply to message #485787] Tue, 15 September 2009 10:38 Go to previous message
Thanks again for your quick response, Ketan. After I had posted my question I kept trying to get this to work. I found this code was also successful without using the KeyStroke specification:
textEditor.typeText("test line " + l);
textEditor.pressShortcut(SWT.CR, SWT.LF);
Michelle
Previous Topic:Table items background color doesn't work
Next Topic:Is SWTbot supposed to work with Eclipse 3.3.2?
Current Time: Wed Dec 03 17:21:58 EST 2025
Powered by FUDForum. Page generated in 0.02832 seconds
