example not working [message #3929] |
Thu, 30 March 2006 06:48  |
Originally posted by: mike.borft.student.utwente.nl
Hi all,
I also tried to get the example to work. I followed the instructions and
downloaded and unzipped all the prerequisites. Then I downloaded the
plugins from cvs, and compiled them.
So far, so good. The plugins compiled (although I had to add a few
dependancies, beforehand). If I look at help->about->plugin details, de
bpel plugins are listed. (the .jar files are in the eclipse/plugins dir).
But opening the example (which I checked out of cvs) doesn't quite work! It
gives me the error shown below. I'm running:
Version: 3.2.0
Build id: I20060223-1656
which is the M5 release, on a Suse Linux machine.
I hope somebody can point me in the right direction.
thanks in advance,
Mike
Error:
org.eclipse.ui.PartInitException: Error opening editor. Can't read input
file.
at org.eclipse.bpel.ui.BPELEditor.init(BPELEditor.java:1591)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:825)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:578)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:367)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:555)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 5)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:266)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1140)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1093)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 12)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 78)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:453)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:101 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:440)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:110 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:214)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:204)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:805)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:705)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:666)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2390)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2325)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2317)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2303)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2298)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2275)
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:132)
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:223)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:480)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1074)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3158)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2838)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: example not working [message #5701 is a reply to message #3929] |
Mon, 28 August 2006 11:40  |
Originally posted by: pbriere.linagora.com
Tried to create an empty simple eclipse project before ?
Phil
Mike! a écrit :
> Hi all,
> Version: 3.2.0
> thanks in advance,
> Mike
> Error:
> file.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03258 seconds
