Home » Eclipse Projects » SWTBot » Running SWTBot testcase with ant
Running SWTBot testcase with ant [message #44986] Wed, 22 July 2009 18:59 Go to next message
I tried running the steps for executing SWTBot tests from Ant. I followed
the tutorial which was helpful.
When I run ant from the cmd prompt, it goes through the build.xml, says
it's running my testcase and ends with a Build Successful.
In the tutorial I see that it shows Eclipse run and steps performed. Mine
does not visually show this, but does take the time I would expect it to.
I also get a "Java Result: 13"
I tried going back through using what the tutorial uses as far as code
goes.
Not sure what may be different on my end. I'm running WinXP64 as my OS and
have my environment variables set correctly to run ant.
Any help or suggestions would be greatly appreciated.
Derek
Buildfile: build.xml
suite:
init:
swtbot-test:
java-test:
[echo] Running MySampleTestCase. Result file:
C:/eclipse_ganymede/eclipse/results/MySampleTestCase.xml.
[java] Java Result: 13
collect-results:
[style] Warning: the task name <style> is deprecated. Use <xslt>
instead.
[style] Transforming into C:\eclipse_ganymede\eclipse\results
cleanup:
run:
BUILD SUCCESSFUL
Total time: 11 seconds
build.xml:
<?xml version="1.0" encoding="UTF-8" ?>
<project name="testsuite" default="run" basedir=".">
<property name="eclipse-home" value="C:/eclipse_ganymede/eclipse" />
<property name="plugin-name" value="com.eclipse.swtbot.tester" />
<property name="test-classname" value="MySampleTestCase" />
<property name="library-file"
value=" ${eclipse-home}/plugins/org.eclipse.swtbot.eclipse.junit4.he adless_2.0.0.371-dev-e34/library.xml "
<target name="suite">
<property name="jvmOption" value=""></property>
<property name="temp-workspace" value="workspace" />
<delete dir="${temp-workspace}" quiet="true" />
<ant target="swtbot-test" antfile="${library-file}"
dir="${eclipse-home}">
<property name="data-dir" value="${temp-workspace}" />
<property name="plugin-name" value="${plugin-name}" />
<property name="classname" value="${test-classname}" />
<property name="vmargs" value=" -Xms128M -Xmx368M -XX:MaxPermSize=256M
${jvmOption}" />
</ant>
</target>
<target name="cleanup" />
<target name="run" depends="suite,cleanup">
</target>
</project>
Re: Running SWTBot testcase with ant [message #45076 is a reply to message #44986] Thu, 23 July 2009 00:20 Go to previous messageGo to next message
> followed the tutorial which was helpful.
> Mine does not visually show this, but does take the time I would expect
> it to.
Can you look at the generated XML file ? It contains the JUnit report
for the tests. You may also optionally import it into the junit view to
see any errors.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
Re: Running SWTBot testcase with ant [message #45109 is a reply to message #45076] Thu, 23 July 2009 01:16 Go to previous messageGo to next message
One reason could be incorrect os value. Please check these value are
correct w.r.to your O.S.
-os win32 -arch x86
build.xml
<property name="os" value="win32" />
<property name="ws" value="workspace" />
<property name="arch" value="x86" />
Just to verify if it is due incorrect os parameter value, open the
library.xml file exists in the headless directory and comment the
following line and execute again.
<!--arg line="-os ${os}"/>
Re: Running SWTBot testcase with ant [message #45136 is a reply to message #45109] Thu, 23 July 2009 03:09 Go to previous messageGo to next message
Yes indeed!
I think the wiki page misses these values.
Derek the valid values are:
os: win32/linux/macosx
ws: win32/wpf/gtk/cocoa/carbon
arch: x86/x86_64
Ketan
> -os win32 -arch x86
> build.xml
Re: Running SWTBot testcase with ant [message #45194 is a reply to message #45076] Thu, 23 July 2009 12:35 Go to previous messageGo to next message
>> it to.
> see any errors.
The generated XML file that was put in the results folder doesn't have any
information in it. Just:
<testsuites />
The text file gives more information:
Looks like it's got a bunch of class not found errors, though, I really
don't know what these actually mean. >_>;;
Install location:
file:/c:/eclipse_ganymede/eclipse/
Configuration file:
file:/c:/eclipse_ganymede/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/eclipse_ganymede/eclipse/plugins/org.eclipse.osgi_3 .4.3.R34x_v20081215-1030.jar
Framework classpath:
Debug options:
file:/C:/eclipse_ganymede/eclipse/.options not found
Time to load bundles: 16
Starting application: 3609
!SESSION 2009-07-23 10:12:13.705
eclipse.buildId=M20090211-1700
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86_64, WS=workspace, NL=en_US
Framework arguments: -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,C:/eclipse_ganymede/eclipse/MySampleTestC ase.xml
formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter
-testPluginName com.eclipse.swtbot.tester -className MySampleTestCase
Command-line arguments: -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -data
workspace
-testPluginName com.eclipse.swtbot.tester -className MySampleTestCase -os
win32 -ws workspace -arch x86_64 -consoleLog -debug
!ENTRY org.eclipse.osgi 4 0 2009-07-23 10:12:17.361
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.ui.workbench (158).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:188)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.core.launcher.Main.main(Main.java:30)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 34 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:483)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 40 more
Root exception:
... 40 more
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.swtbot.eclipse.junit4.headless was unable to load class
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 17 more
Caused by: org.osgi.framework.BundleException: The activator
... 29 more
... 34 more
... 40 more
!ENTRY org.eclipse.osgi 2 0 2009-07-23 10:12:17.408
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-07-23 10:12:17.408
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.filesystem.win32.x86 _1.1.0.v20080604-1400.jar
[23] was not resolved.
!SUBENTRY 2 org.eclipse.core.filesystem.win32.x86 2 0 2009-07-23
10:12:17.408
!MESSAGE Platform filter did not match: (& (osgi.os=win32) (osgi.arch=x86))
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-07-23 10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.0. I20080521.jar
[26] was not resolved.
!SUBENTRY 2 org.eclipse.core.net.win32.x86 2 0 2009-07-23 10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.resources.win32.x86_ 3.4.0.v20071204.jar
[29] was not resolved.
!SUBENTRY 2 org.eclipse.core.resources.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.equinox.launcher.win32.wi n32.x86_1.0.101.R34x_v20080731/
[54] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Platform filter did not match: (& (osgi.ws=win32) (osgi.os=win32)
(osgi.arch=x86))
!MESSAGE Bundle
reference:file:plugins/org.eclipse.equinox.security.win32.x8 6_1.0.0.v20080529-1600.jar
[80] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.security.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.4.1 .v3452b.jar
[131] was not resolved.
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86 2 0 2009-07-23 10:12:17.424
(osgi.arch=x86))
!MESSAGE Bundle
reference:file:plugins/org.eclipse.ui.win32_3.2.100.v2008040 8-0800.jar
[157] was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2009-07-23 10:12:17.424
!MESSAGE Platform filter did not match: (osgi.ws=win32)
Re: Running SWTBot testcase with ant [message #45224 is a reply to message #45109] Thu, 23 July 2009 12:37 Go to previous messageGo to next message
> -os win32 -arch x86
> build.xml
I tried commenting out that line. It runs the same as it had before. I
also added the os/ws/arch to my build.xml.
So perhaps there is a different problem I am having.
Though it's good that I have that in my build.xml now, thanks for the help.
-Derek
Re: Running SWTBot testcase with ant [message #45253 is a reply to message #45136] Thu, 23 July 2009 13:23 Go to previous messageGo to next message
> Yes indeed!
> arch: x86/x86_64
I updated my build.xml with:
<property name="ws" value="win32" />
<property name="arch" value="x86_64" />
What is the difference when I've seen "ws" equal to "workspace"?
-Derek
Re: Running SWTBot testcase with ant [message #45281 is a reply to message #45253] Thu, 23 July 2009 13:47 Go to previous messageGo to next message
ws stands for Windowing System., not workspace. It's the native api for
the GUI, such as gtk or motif for linux and win32 or wpf (windows vista)
for windows.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Running SWTBot testcase with ant [message #45310 is a reply to message #45281] Thu, 23 July 2009 13:54 Go to previous messageGo to next message
> for windows.
Windowing System. Ah good. Thanks for the explanation :)
Derek
Re: Running SWTBot testcase with ant [message #45340 is a reply to message #45194] Thu, 23 July 2009 18:22 Go to previous messageGo to next message
OK, I got some help diagnosing and it looks like the primary reason is
because I had a mismatch with running 32-bit SWT libraries on 64-bit JVM.
It was a mistake on my part since I had it pointing to 64-bit JVM instead
of 32-bit.
Oops!
Thanks guys,
Derek
Re: Running SWTBot testcase with ant [message #475279 is a reply to message #45340] Wed, 05 August 2009 18:27 Go to previous messageGo to next message
Originally posted by: saleem.khan.insha.gmail.com
I am also getting the same issue, did you you solve that.
Please post if it's working
Re: Running SWTBot testcase with ant [message #475489 is a reply to message #475279] Wed, 05 August 2009 18:37 Go to previous message
Yes I was able to get it solved.
I am running WindowsXP 64-bit. I had my environment variables pointing to
the wrong locations. I had 64-bit JRE installed, but I didn't have the
32-bit JRE installed.
The variables I had set just needed to be switched over and I had to have
it correctly in my build.xml
Above are what I needed it set to. And I needed the environment variables
to point correctly to use the appropriate JRE.
Previous Topic:Testing an exported rcp-app
Next Topic:weired behavior when Running SWTBot Plugin Test from Ant
Current Time: Sat Nov 08 17:57:45 EST 2025
Powered by FUDForum. Page generated in 0.04235 seconds
