Home » Eclipse Projects » Subversive » Using Subversive on tree elements that represents more than one folder
Using Subversive on tree elements that represents more than one folder [message #44982] Mon, 27 April 2009 11:07 Go to next message
I have a view with "virual" elments that represent different folders from
the workspace. Can I use the Team menu and Subversive functionality on it?
(It would be the same as I selected more than one "normal" folder in the
Package explorer and then use the Team menu. A normal "virtual to IResource"
adapter is not enough because I have to work with more than one folder.)
Is it possible to implement this?
Istvan
Re: Using Subversive on tree elements that represents more than one folder [message #45928 is a reply to message #44982] Tue, 05 May 2009 11:11 Go to previous messageGo to next message
Hello Istvan,
I can advice you to learn about logical model integration in team support.
You can find more info about it in your Eclipse help: Help/Help Contents
menu in Platform Plug-in Developer Guide/Programmer's Guide/Team
support/Support for Logical Model Integration. Subversive already supports
logical models and you just need to support them in your model, in short,
you need to adapt your model elements in model views to ResourceMapping
(it's not enough to adapt to IResource).
Feel free to contact me if you have any questions here.
> Hello,
> IResource" adapter is not enough because I have to work with more than one
> folder.)
> Istvan
Re: Using Subversive on tree elements that represents more than one folder [message #46065 is a reply to message #45928] Tue, 05 May 2009 16:56 Go to previous message
Hello Igor,
Thank you for your tip and offering your help.
I implemented a quick test using the code snippets found in the help and it
works.
I tried synchronizing, commit and revert on my model element and there was
no problem.
I realized again how powerful tool the Eclipse is... :)
Best wishes,
Istvan
"Igor Burilo" <igor.burilo@polarion.org> wrote in message
news:gtpkvv$3o4$1@build.eclipse.org...
> Hello Istvan,
>> Hello,
>> it?
>> one folder.)
>> Thanks,
>> Istvan
Previous Topic:Latest SVN Update - when is it going to be fixed?
Next Topic:Latest update severely pooches Eclipse
Current Time: Sat Nov 08 13:32:10 EST 2025
Powered by FUDForum. Page generated in 0.03166 seconds
