Home » Archived » Visual Editor (VE) » copy and paste doesn't work after installing VE
copy and paste doesn't work after installing VE [message #44929] Tue, 29 June 2004 14:09 Go to next message
I have Eclipse 3.0 released with VE20040628 with all required GEF and EMF.
VE Editor works fine but I have one annoying side effect after
installing VE.
I cannot copy/cut and paste of my code anymore in my java editor once I
install VE.
Does anyone have same issue? How can I make Copy and Paste work?
There is nothing in Error log that relate to this issue.
Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #44956 is a reply to message #44929] Tue, 29 June 2004 15:22 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
1) What versions of Eclipse, VE, GEF, and EMF are you using?
2) What is your operating system?
3) What is your locale? Is it English?
It works fine on our Windows XP systems. No problem with cut and paste.
Rich
Sang Uk Seong wrote:
> Hello,
> installing VE.
> install VE.
> Sang Uk Seong
Thanks, Rich Kulp
Re: copy and paste doesn't work after installing VE [message #44998 is a reply to message #44956] Tue, 29 June 2004 16:26 Go to previous messageGo to next message
VE S20040628, EMF R200406280827 GEF 3.0
Eclipse 3.0 SDK (20040625)
Windows XP
It is Korean (English Windows XP with English Regional and Korean
non-Unicode Program Locale (In Advanced tab)
(I will try to change back to English see if it works...)
I had same problem with RC2 with previous Stable builds as well like
S2004622
Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #45024 is a reply to message #44998] Tue, 29 June 2004 16:37 Go to previous message
Hello Rich,
It works now... I don't know if resetting regional setting or simply
restarting the system, my eclipse now behaves as it should be.
Sorry for the trouble.
Sang Uk Seong
> Windows XP
> S2004622
> Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #593105 is a reply to message #44929] Tue, 29 June 2004 15:22 Go to previous message
Rich
> Hello,
> installing VE.
> install VE.
> Sang Uk Seong
Thanks, Rich Kulp
Re: copy and paste doesn't work after installing VE [message #593122 is a reply to message #44956] Tue, 29 June 2004 16:26 Go to previous message
Windows XP
S2004622
Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #593135 is a reply to message #44998] Tue, 29 June 2004 16:37 Go to previous message
Hello Rich,
Sang Uk Seong
> Windows XP
> S2004622
> Sang Uk Seong
Previous Topic:eclipse stops responding
Next Topic:Can't create Visual Classes
Current Time: Thu Nov 13 02:46:54 EST 2025
Powered by FUDForum. Page generated in 0.03863 seconds
