Home » General (non-technical) » Eclipse Foundation » SWT/JFACE - How to set a selection on a pop-up menu
SWT/JFACE - How to set a selection on a pop-up menu [message #44885] Fri, 09 March 2007 02:10 Go to next message
Originally posted by: baiyf99.yahoo.com
Hope someone could advise me on the above issue.
I have written a pop-up menu using MenuManager.
For example, MenuItems are "Save" and "Cancel"
I would like to program using a timer to set a selection on one of
the menu items (for example, Save in this case), so that a save operation
is done at certain time intervals.
Please advise how (preferably with some java coding) on how to set the
selection to that particular menu item.
I have written a simple method. viewer in this case, is a Tree Viewer.
I am not sure what/how to pass in the selection parameter, in this case to
set the selection to Save MenuItem.
Pls advise, thanks.
Sally
//Set by the timer in certain time intervals to set Save MenuItem
public void setSelection(IStructuredSelection selection) {
if ((viewer != null) && (viewer.getSelection() == null)) {
viewer.setSelection(selection);
Re: SWT/JFACE - How to set a selection on a pop-up menu [message #44921 is a reply to message #44885] Fri, 09 March 2007 03:12 Go to previous message
Sally,
This newsgroup is for discussion the operations of the Eclipse
organization itself. Please use the platform or newcomers newsgroup for
questions like this. (You're question totally confuses me. I don't
understand how the menu item is related to a selection in a viewer.)
sally wrote:
> operation is done at certain time intervals.
> case to set the selection to Save MenuItem.
> Pls advise, thanks.
> Sally
> public void setSelection(IStructuredSelection selection) { if
> viewer.setSelection(selection); }
Previous Topic:how remove unneeded tag
Next Topic:Help request about Eclipse TEST
Current Time: Fri Nov 07 07:07:10 EST 2025
Powered by FUDForum. Page generated in 0.23808 seconds
