AJDT edit part issues [message #44819] |
Thu, 02 December 2004 15:46  |
Originally posted by: vranganath.sbcglobal.net
I am using Eclipse (I20041201) with AJDT (20041125170637). I get the following exceptions when I try to open a .aj file in
AspectJ editor.
java.lang.NoSuchMethodError:
org.eclipse.ajdt.parserbridge.AJCompilationUnitStructureRequ estor.resolveDuplicates(Lorg/eclipse/jdt/core/IJavaElement;) V
org.eclipse.ajdt.parserbridge.AJCompilationUnitStructureRequ estor.enterType(AJCompilationUnitStructureRequestor.java:157 )
org.eclipse.ajdt.parserbridge.AJCompilationUnitStructureRequ estor.enterClass(AJCompilationUnitStructureRequestor.java:78 )
at org.eclipse.ajdt.parserbridge.AJSourceElementParser.notifySo urceElementRequestor(AJSourceElementParser.java:1051)
at org.eclipse.ajdt.parserbridge.AJSourceElementParser.notifySo urceElementRequestor(AJSourceElementParser.java:716)
at org.eclipse.ajdt.parserbridge.AJSourceElementParser.parseCom pilationUnit(AJSourceElementParser.java:1200)
at org.eclipse.ajdt.core.javaelements.AJCompilationUnit.buildSt ructure(AJCompilationUnit.java:199)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:203)
at org.eclipse.ajdt.core.javaelements.AJCompilationUnit.generat eInfos(AJCompilationUnit.java:147)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:553)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:291)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:277)
at org.eclipse.ajdt.core.javaelements.AJCompilationUnit.getElem entInfo(AJCompilationUnit.java:107)
at org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaEl ement.java:232)
at org.eclipse.ajdt.core.javaelements.AJCompilationUnit.getChil dren(AJCompilationUnit.java:326)
at org.eclipse.jdt.internal.core.JavaElement.getChildrenOfType( JavaElement.java:246)
at org.eclipse.jdt.internal.core.CompilationUnit.getTypes(Compi lationUnit.java:828)
at org.eclipse.ajdt.core.javaelements.AJCompilationUnit.getType s(AJCompilationUnit.java:331)
at org.eclipse.jdt.internal.core.NameLookup.<init>(NameLookup.java:147)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:2335)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:2346)
at org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnvironment.java:72)
at org.eclipse.jdt.internal.core.JavaProject.newSearchableNameE nvironment(JavaProject.java:2361)
at org.eclipse.jdt.internal.core.Openable.codeSelect(Openable.j ava:126)
at org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(Com pilationUnit.java:300)
at org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(Com pilationUnit.java:294)
org.eclipse.jdt.internal.ui.text.java.hover.AbstractJavaEdit orTextHover.getHoverInfo(AbstractJavaEditorTextHover.java:10 8)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.g etHoverInfo(BestMatchHover.java:102)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaEditorTextHo verProxy.getHoverInfo(JavaEditorTextHoverProxy.java:69)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextView erHoverManager.java:160)
at org.eclipse.jdt.internal.core.CancelableNameEnvironment.<init >(CancelableNameEnvironment.java:26)
at org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.p rocess(CompilationUnitProblemFinder.java:148)
at org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.p rocess(CompilationUnitProblemFinder.java:213)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation. executeOperation(ReconcileWorkingCopyOperation.java:78)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:700)
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:739)
at org.eclipse.jdt.internal.core.CompilationUnit.reconcile(Comp ilationUnit.java:1105)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.reconcile(JavaReconcilingStrategy.java:97)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.reconcile(JavaReconcilingStrategy.java:133)
at org.eclipse.jdt.internal.ui.text.CompositeReconcilingStrateg y.reconcile(CompositeReconcilingStrategy.java:86)
at org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStr ategy.reconcile(JavaCompositeReconcilingStrategy.java:96)
at org.eclipse.jface.text.reconciler.MonoReconciler.process(Mon oReconciler.java:75)
at org.eclipse.jdt.internal.ui.text.JavaReconciler.process(Java Reconciler.java:318)
at org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:204)
Any clues what may be wrong? Would using 1.2.0M1 help?
waiting for reply,
- Venkatesh
Re: AJDT edit part issues [message #44849 is a reply to message #44819] |
Thu, 02 December 2004 16:09  |
Originally posted by: mchapman.uk.ibm.com
Hi Venkatesh,
You should be fine with that development version of AJDT, but the problem
is with your Eclipse version. There are two versions of AJDT, one for
Eclipse 3.0, and one for Eclipse 3.1, so you need to make sure you use the
right update site. Here are the update site URLs for the development
builds:
Eclipse 3.0:
http://download.eclipse.org/technology/ajdt/30/dev/update
Eclipse 3.1:
http://download.eclipse.org/technology/ajdt/31/dev/update
The other (potential) problem is that you are using an integration build
of Eclipse, but AJDT is only tested with milestone builds and
release builds.
I suggest first trying the 3.1 version of AJDT with Eclipse
build I20041201, and if that doesn't work, fall back to Eclipse 3.1M3.
Hope that helps,
Matt.
On Thu, 02 Dec 2004 14:46:52 -0600, Venkatesh Prasad Ranganath wrote:
> AspectJ editor.
> at
> at
> waiting for reply,
> - Venkatesh
Re: AJDT edit part issues [message #585229 is a reply to message #44819] |
Hi Venkatesh,
builds:
Eclipse 3.0:
Eclipse 3.1:
release builds.
Hope that helps,
Matt.
> AspectJ editor.
> at
> at
> waiting for reply,
> - Venkatesh
FUDForum. Page generated in 0.09099 seconds
