| highlight elements in code editor [message #44817] |
Wed, 05 March 2008 04:08  |
Originally posted by: xxx.xxx.no
When an element in my code editor becomes interesting enough, it is
assigned a landmark and that element in the code is highlighted.
Unfortunately, the hightlight color scheme does not work well with my java
editor's colour settings. I cannot see the text hightlighted because they
are the same colour.
I have tried changing every colour setting under preferences but I cannot
change the highlight colour. This is not a problem with mylyn deactivated.
Question: Is it possible to change the highlight colour and how?
thanks Neil
| Re: highlight elements in code editor [message #47073 is a reply to message #45607] |
Tue, 15 April 2008 12:16  |
Sean,
I added a short section on how to do this to the User Guide. Please
feel free to expand on it. Note that to do this you would want to
change the Java Editor font color.
http://wiki.eclipse.org/Mylyn_User_Guide#UI_Settings
Mik
Sean wrote:
> I have a corollary question: how can I change the color of the Landmark
> foreground? I use high-contrast black for my screen colors and the
> Landmarks look like they are bold and very close to black or actually
> black, which makes them very hard for me to see. I had already found my
> way to the background color setting. I looked in the FAQ but I didn't
> see either question covered.
> I'll be more than happy to add the previous solution and if it exists,
> the solution to my question. Has anyone else already added the previous
> solution to the FAQ and I just missed it?
> Thanks for any help -
> Sean
| Re: highlight elements in code editor [message #588347 is a reply to message #44817] |
Fri, 07 March 2008 00:23  |
Hi Neil,
We don't set a higlight color for landmarks by default since there is a
considerable amount of coloring in the Java editor already. However,
you can configure the background color for landmarks via Window ->
Preferences -> General -> Editors -> Text Editors -> Annotations.
Mik
> java editor's colour settings. I cannot see the text hightlighted
> because they are the same colour.
> cannot change the highlight colour. This is not a problem with mylyn
> deactivated.
> thanks Neil
| Re: highlight elements in code editor [message #588554 is a reply to message #44942] |
Thu, 13 March 2008 18:37  |
way to the background color setting. I looked in the FAQ but I didn't see
I'll be more than happy to add the previous solution and if it exists, the
Sean
| Re: highlight elements in code editor [message #589078 is a reply to message #45607] |
Sean,
Mik
> Sean
FUDForum. Page generated in 0.10498 seconds
