Home » Archived » XML Schema Definition (XSD) » XSDSchema serialization
XSDSchema serialization [message #44770] Tue, 18 May 2004 11:30 Go to next message
Is there a chance to serialize an XSDSchema ? I having performance trouble
with XSDSchema instanciation from DOM, and in my case, can be avoided if I
can serialize and XSDSchema.
Re: XSDSchema serialization [message #44807 is a reply to message #44770] Tue, 18 May 2004 11:40 Go to previous messageGo to next message
Rodolfo,
Doing xsdSchema.eResource().save(System.out, null) should serialize your
instance.
SubstitutionGroups Help! [message #44889 is a reply to message #44807] Thu, 20 May 2004 17:05 Go to previous messageGo to next message
Originally posted by: jmurphy.mindreef.com
Hi everyone.
I'm trying to understand how to use XSD's SubstitutionGroups support. I
understand the XML/Schema construct at a practical level but I'm unclear
about the APIs:
1. ElementDecl.getSubstitutionGroupExclusions
2. ElementDecl.getSubstitutionGroup
3. ElementDecl.getSubstitutionGroupAffiliation
That I want to do is compile a list of substitutions given an abstract
element declaration. I expected to be able to call
elemDecl.getSubstitutionGroup and ave that return all of the
elementDecls that can substitute. But only the element itself is
included. An I out to lunch? Alsi what is an affiliation and an exculsion?
Jim
Mindreef, Inc.
Re: SubstitutionGroups Help! [message #44906 is a reply to message #44889] Thu, 20 May 2004 19:04 Go to previous messageGo to next message
Jim,
I'm not sure whether you have lunch in or out. ;-)
Each of these things have Javadoc that point at where the concept is defined in
the spec, so there's no point in repeating that information. I know the spec is
not much fun to read, but it's very precise. The basic idea is that
getSubstitutionGroupAffiliation is a concrete relation that set's up the
substitution group by saying "This element belongs to that element's group".
The getSubstitutionGroupExclusions defines limitations on what kinds of elements
can be in the element's group. And the getSubstitutionGroup returns all the
elements that are directly or indirectly in the group by virtue of the
affiliations.
Were you trying this out with any particular examples in mind?
Jim Murphy wrote:
> Hi everyone.
> about the APIs:
> Thanks
> Jim
> Mindreef, Inc.
Re: SubstitutionGroups Help! [message #45191 is a reply to message #44906] Fri, 21 May 2004 13:07 Go to previous message
Lol - sorry bout that. Kind of lost it yesterday. :)
Thanks for the descriptions - you're spot on. I can *read* the spec but
that doesn't mean I can understand it. If I understand you right this
means the getSubstitutioGroup returns the set of elements that can
substitute for and element while the getSubsitutionGroupAffiliations is
a "back pointer" to the element where this element can substitute.
Actually it turns out the problem I was tracking down was the result of
a bad schema - but pretty understandable.
The author setup a pretty simple substitutionGroup based ona global
element declaration called: fred of type fredType. But, he went on to
attempt to use "fred" by creating a sequence of local elements named
"fred" of type "fredType". "Clearly" the 2 element decls are unrelated
but...
Jim Murphy
Mindreef, Inc.
Ed Merks wrote:
> Jim,
> affiliations.
> Jim Murphy wrote:
>>Hi everyone.
>>about the APIs:
>>Thanks
>>Jim
>>Mindreef, Inc.
Re: XSDSchema serialization [message #587208 is a reply to message #44770] Tue, 18 May 2004 11:40 Go to previous message
Rodolfo,
instance.
SubstitutionGroups Help! [message #587261 is a reply to message #44807] Thu, 20 May 2004 17:05 Go to previous message
Hi everyone.
about the APIs:
Jim
Mindreef, Inc.
Re: SubstitutionGroups Help! [message #587280 is a reply to message #44889] Thu, 20 May 2004 19:04 Go to previous message
Jim,
affiliations.
Jim Murphy wrote:
> Hi everyone.
> about the APIs:
> Thanks
> Jim
> Mindreef, Inc.
Re: SubstitutionGroups Help! [message #587359 is a reply to message #44906] Fri, 21 May 2004 13:07 Go to previous message
but...
Jim Murphy
Mindreef, Inc.
Ed Merks wrote:
> Jim,
> affiliations.
> Jim Murphy wrote:
>>Hi everyone.
>>about the APIs:
>>Thanks
>>Jim
>>Mindreef, Inc.
Previous Topic:A question about walkers/visitors
Next Topic:Retrieving user information
Current Time: Sat Nov 08 20:26:28 EST 2025
Powered by FUDForum. Page generated in 1.04092 seconds
