| XSDSchema serialization [message #44770] |
Tue, 18 May 2004 11:30  |
Is there a chance to serialize an XSDSchema ? I having performance trouble
with XSDSchema instanciation from DOM, and in my case, can be avoided if I
can serialize and XSDSchema.
| Re: SubstitutionGroups Help! [message #45191 is a reply to message #44906] |
Fri, 21 May 2004 13:07  |
Lol - sorry bout that. Kind of lost it yesterday. :)
Thanks for the descriptions - you're spot on. I can *read* the spec but
that doesn't mean I can understand it. If I understand you right this
means the getSubstitutioGroup returns the set of elements that can
substitute for and element while the getSubsitutionGroupAffiliations is
a "back pointer" to the element where this element can substitute.
Actually it turns out the problem I was tracking down was the result of
a bad schema - but pretty understandable.
The author setup a pretty simple substitutionGroup based ona global
element declaration called: fred of type fredType. But, he went on to
attempt to use "fred" by creating a sequence of local elements named
"fred" of type "fredType". "Clearly" the 2 element decls are unrelated
but...
Jim Murphy
Mindreef, Inc.
Ed Merks wrote:
> Jim,
> I'm not sure whether you have lunch in or out. ;-)
> Each of these things have Javadoc that point at where the concept is defined in
> the spec, so there's no point in repeating that information. I know the spec is
> not much fun to read, but it's very precise. The basic idea is that
> getSubstitutionGroupAffiliation is a concrete relation that set's up the
> substitution group by saying "This element belongs to that element's group".
> The getSubstitutionGroupExclusions defines limitations on what kinds of elements
> can be in the element's group. And the getSubstitutionGroup returns all the
> elements that are directly or indirectly in the group by virtue of the
> affiliations.
> Were you trying this out with any particular examples in mind?
> Jim Murphy wrote:
>>Hi everyone.
>>I'm trying to understand how to use XSD's SubstitutionGroups support. I
>>understand the XML/Schema construct at a practical level but I'm unclear
>>about the APIs:
>>1. ElementDecl.getSubstitutionGroupExclusions
>>2. ElementDecl.getSubstitutionGroup
>>3. ElementDecl.getSubstitutionGroupAffiliation
>>That I want to do is compile a list of substitutions given an abstract
>>element declaration. I expected to be able to call
>>elemDecl.getSubstitutionGroup and ave that return all of the
>>elementDecls that can substitute. But only the element itself is
>>included. An I out to lunch? Alsi what is an affiliation and an exculsion?
>>Thanks
>>Jim
>>Mindreef, Inc.
| Re: XSDSchema serialization [message #587208 is a reply to message #44770] |
Tue, 18 May 2004 11:40  |
Rodolfo,
Doing xsdSchema.eResource().save(System.out, null) should serialize your
instance.
| SubstitutionGroups Help! [message #587261 is a reply to message #44807] |
Thu, 20 May 2004 17:05  |
Originally posted by: jmurphy.mindreef.com
Hi everyone.
about the APIs:
Jim
Mindreef, Inc.
| Re: SubstitutionGroups Help! [message #587280 is a reply to message #44889] |
Thu, 20 May 2004 19:04  |
Jim,
affiliations.
Jim Murphy wrote:
> Hi everyone.
> about the APIs:
> Thanks
> Jim
> Mindreef, Inc.
| Re: SubstitutionGroups Help! [message #587359 is a reply to message #44906] |
but...
Jim Murphy
Mindreef, Inc.
Ed Merks wrote:
> Jim,
> affiliations.
> Jim Murphy wrote:
>>Hi everyone.
>>about the APIs:
>>Thanks
>>Jim
>>Mindreef, Inc.
FUDForum. Page generated in 0.76632 seconds
