Home » Modeling » TMF (Xtext) » Using xtext for comprehensive languages
| Using xtext for comprehensive languages [message #44764] |
Fri, 22 May 2009 10:34  |
Is xtext project aimed at small DSL's or is it also suitable for
comprehensive languages? (EMFText seems to have big languages such as java
in its language zoo.)
Particularly, I'm interested to know about the use of xtext in JVM-based
languages such as groovy, scala, jython, jruby, etc. Does the fact that
these languages can directly call the java API make anything any easier?
Would xtext be able to provide joint java compilation for these languages?
| Re: Using xtext for comprehensive languages [message #44790 is a reply to message #44764] |
Fri, 22 May 2009 11:35   |
Hi Auerliano!
Xtext's primary target is to build external textual DSLs. It is not
intended to create full-fledged general purpose programming languages. I
think you would face many limitations when trying to build "big"
languages. It is simply not the right tooling for that. You would need
parser generators with more possibilities, like Antlr. Xtext uses them
itself and abstract certain things, gaining simplicity and abstraction,
but loosing some features.
Xtext is a perfect choice for creating good external DSLs with high
efficiency. This is normally the way I use it in real projects and which
works well.
~Karsten
On 22.05.09 16:34, Auerliano wrote:
> java in its language zoo.)
| Re: Using xtext for comprehensive languages [message #44822 is a reply to message #44790] |
Fri, 22 May 2009 12:48   |
Hi Karsten,
Thanks for the information. One question remains here: how come EMFText
does support general languages? I had the impression that EMFText and
xtext are very similar.
Karsten Thoms wrote:
> Hi Auerliano!
> works well.
> ~Karsten
| Re: Using xtext for comprehensive languages [message #44917 is a reply to message #44764] |
Fri, 22 May 2009 14:13   |
Hi Auerlino,
with TMF Xtext it is possible and reasonable to build more complex
languages. Karsten was referring to oAW Xtext which had some limitations
regarding expression based grammars (left factored grammars created
verbose trees). This is solved in TMF Xtext. Also scalability problems
we had in oAW Xtext are solved.
TMF Xtext is absolutely capable of hosting big general-purpose
languages. One thing we don't have yet (but we will add as soon as
someone needs them after Galileo) is predicates. In Anltr you can define
semantic and syntactic predicates. There are some languages, where you
might need these features. Anyway, we didn't need them so far, so we
haven't yet added them. If you need them come up with a bugzilla and
we'll take care if it.
To proove that Xtext supports more complicated languages, we'll
implement one in the next release and ship it as a library. So people
can extend / modify the language and add their own domain-specific
concepts but can reuse the expressions and the typesystem and of course
can call to Java, because we want to ship that language with a mapping
to Java.
So the reason why other frameworks have a language zoo and have
general-purpose languages therin and Xtext has not, is just because we
so far put all our resources into the framework's code.
Sven
Auerliano schrieb:
| Re: Using xtext for comprehensive languages [message #44941 is a reply to message #44917] |
Fri, 22 May 2009 14:18   |
Hi Sven,
That's really good news! One question is, having a compiler like jython or
scala, (or even java), how is it possible to avoid a parser like antlr and
use the compiler directly in xtext?
Sven Efftinge wrote:
> Hi Auerlino,
> to Java.
> Cheers,
> Sven
> Auerliano schrieb:
| Re: Using xtext for comprehensive languages [message #45101 is a reply to message #44917] |
Fri, 22 May 2009 14:27   |
> Hi Auerlino,
By 'next release' you mean in June 2010?
> So people
> to Java.
> Cheers,
> Sven
> Auerliano schrieb:
| Re: Using xtext for comprehensive languages [message #45126 is a reply to message #44941] |
Fri, 22 May 2009 15:50   |
I'm not sure what you mean.
This things you've listed are all languages which have their own parser
and compiler. You could reimplement those languages with Xtext or you
could transform information written in your Xtext-based language into
something the respective compiler "understands", i.e. source code or
maybe an abstract syntax tree.
So this would be basically a code generator which generates Jython,
Scala or even Java.
Did that answer your question?
Sven
Auerliano schrieb:
> Hi Sven,
> or scala, (or even java), how is it possible to avoid a parser like
> antlr and use the compiler directly in xtext?
>> Hi Auerlino,
>> limitations regarding expression based grammars (left factored
>> grammars created verbose trees). This is solved in TMF Xtext. Also
>> scalability problems we had in oAW Xtext are solved.
>> define semantic and syntactic predicates. There are some languages,
>> where you might need these features. Anyway, we didn't need them so
>> far, so we haven't yet added them. If you need them come up with a
>> bugzilla and we'll take care if it.
>> course can call to Java, because we want to ship that language with a
>> mapping to Java.
>> Cheers,
>> Sven
>> Auerliano schrieb:
>>> Hi,
>>> JVM-based languages such as groovy, scala, jython, jruby, etc. Does
>>> the fact that these languages can directly call the java API make
>>> anything any easier? Would xtext be able to provide joint java
| Re: Using xtext for comprehensive languages [message #59447 is a reply to message #58583] |
Thu, 16 July 2009 04:31  |
Hi Dave,
Xtext is based on LL parser generators (such as Antlr) which by
definition do not allow left recursion.
This is not a bug.
Your grammar has a lot of left recursion in it which needs to be left
factored.
That is in principle done like in the following (I don't know the
conceptual names of the different patterns so I'll just add a number):
Pattern1 returns Pattern :
Pattern2 ({Pattern.left=current} ',' right=Pattern2)*;
Pattern2 returns Pattern :
Pattern3 ({Pattern.left=current} '&' right=Pattern3)*;
Pattern3 returns Pattern :
Pattern4 ({Pattern.left=current} '|' right=Pattern4)*;
Pattern :
// ... all the not left recursive stuff goes here separated by '|'
'(' Pattern1 ')';
This at the same time defines operator precedence (In this example '|'
has higher precedence than '&', which is probably not right :-))
See also "tree rewrite actions" in the documentation.
Hope that helps,
Sven
>> Hi Auerlino,
> Left factored grammars are still an issue, when trying to implement the
> following grammar:
> http://www.oasis-open.org/committees/relax-ng/compact-200211 21.html#syntax
> In particular the Pattern rule gives errors when you try to implement it
> with left factoring as specified by this EBNF grammar:
> pattern ::= "element" nameClass "{" pattern "}"
> | "attribute" nameClass "{" pattern "}"
> | pattern ("," pattern)+
> | pattern ("&" pattern)+
> | pattern ("|" pattern)+
> | pattern "?"
> | pattern "*"
> | pattern "+"
> | "list" "{" pattern "}"
> | "mixed" "{" pattern "}"
> | identifier
> | "parent" identifier
> | "empty"
> | "text"
> | [datatypeName] datatypeValue
> | datatypeName ["{" param* "}"] [exceptPattern]
> | "notAllowed"
> | "external" anyURILiteral [inherit]
> | "grammar" "{" grammarContent* "}"
> | "(" pattern ")"
> XText will complain about the let factoring in this Rule when converted
> into XText grammar. Only way I was able to get this to work was to
> rewrite the rule in xtext:
> Pattern:
> (val=(Element | Attribute))+ |
> 'list' '{' pattern+=Pattern* '}' |
> 'mixed' '{' pattern+=Pattern* '}' |
> ID ('=')?|
> 'parent' ID |
> 'empty' |
> 'text' |
> (value=DataTypeValue)+ |
> DataTypeName ('{' param+=Param* '}')* (exceptPattern=ExceptPattern)* |
> 'notAllowed' |
> 'external'uri=AnyURILiteral (inherit=Inherit)* |
> 'grammar' '{' grammarContent+=GrammarContent* '}' |
> '(' group+=Pattern* ')' (continue=',')?
> Element:
> 'element' elemName=NameClass '{' pattern+=Pattern* '}'
> (cardinality=('?' | '+' | '*'))? (continue=(',' | '&' | '|'))?;
> Attribute:
> 'attribute' attrName=NameClass '{' pattern+=Pattern* '}'
> (cardinality='?')? (continue=(',' | '|'))?;
> Which is a messy alternative to the EBNF grammar. I'd be interested in
> knowning how to correctly write this in XText with left factoring.
Current Time: Mon Oct 27 07:27:18 EDT 2025
Powered by FUDForum. Page generated in 0.09574 seconds
