Home » Eclipse Projects » Eclipse Platform » Eclipse Problems
Eclipse Problems [message #44714] Thu, 22 May 2003 21:09 Go to next message
Originally posted by: jdubchak.qwest.net
I'm using Eclipse 2.1 on a Redhat 9 Linux platform with JDK 1.4.1_02 from
Sun. I just want to say how much I like the platform but lately it's been
giving me fits.
I experience frequent crashes at least and at most once a day. I can live
with this because up until now I simply restart and continue on - no
problem.
Except for just tonight, after the crash I get the following error on
restarting the platform:
"Problems during startup. Check the ".log" file in the ".metadata"
directory of your workspace."
Fortunately I'm able to recover from this error by deleting my .metadata
directory in my workspace but now need to reconfigure everything to get
back to getting my work done. But my biggest concern is the relative
frequency with which Eclipse appears to be crashing.
Has anyone else had similar experiences with these regular crashes on
Redhat, or any other Linux distro?
John
Re: Eclipse Problems [message #44733 is a reply to message #44714] Thu, 22 May 2003 21:12 Go to previous messageGo to next message
My partner, which uses the same setup as you (+gtk), have the same problems -
frequent crashes.
I'm still sticking to Windows just because of this sad too say. Are you using
the gtk or motif version?
Jimisola
Re: Eclipse Problems [message #44756 is a reply to message #44733] Thu, 22 May 2003 21:20 Go to previous messageGo to next message
> problems - frequent crashes.
> using the gtk or motif version?
> Jimisola
Yes, there's a tremendous stability difference between Win2K and Redhat 9.
I'm using the gtk+ as well - which I suspect to be my problem.
At least I know I'm not alone :-)
John
Re: Eclipse Problems [message #44789 is a reply to message #44756] Thu, 22 May 2003 22:13 Go to previous messageGo to next message
Note: *Everyone* who sees crashes, frequent or otherwise, regardless of
the platform, should post bugzilla reports describing the circumstances
and configuration of their system in as much detail as possible.
If you are seeing a crash that we do not see, the only way to get it
solved is to give us enough information to find it.
McQ.
In article <bajsq6$m0o$1@rogue.oti.com>, jdubchak <jdubchak@qwest.net> wrote:
> > Regards,
> > Jimisola
> John
Re: Eclipse Problems [message #46888 is a reply to message #44756] Fri, 23 May 2003 15:38 Go to previous messageGo to next message
> > Regards,
> > Jimisola
I've been using Eclipse on Linux for 6 or 7 months and never had it crash.
I don't think GTK is your problem. My environment is Debian Linux "sarge"
with 2.4.20 kernal and GTK 2.0. I have Eclipse 2.1.
Don
> John
Re: Eclipse Problems [message #54586 is a reply to message #44789] Thu, 29 May 2003 14:16 Go to previous message
Originally posted by: debbie_wilson.ca.ibm.com
Another useful detail you can add to the bugzilla report is any information
contained in your .log file located under the .metadata area. Often there is
a stack trace in there which will be very useful to us for solving this
problem.
Deb
"McQ" <mike_wilson@ca.ibm.com> wrote in message
news:mike_wilson-2205032213430001@192.168.1.101...
> McQ.
you
> > > Regards,
> > > Jimisola
9.
> > Thanks,
> > John
Previous Topic:Including icons in a plug-in
Next Topic:Ant, Eclipse Config and JRE
Current Time: Tue Nov 11 08:14:31 EST 2025
Powered by FUDForum. Page generated in 0.04555 seconds
