Home » Eclipse Projects » Plugin Development Environment (PDE) » Target Definition and deployed plugins = class path problem in build.xml
Target Definition and deployed plugins = class path problem in build.xml [message #44649] Wed, 04 February 2009 04:54 Go to next message
i have an rcp application, for which i try to set up an target definition.
In these target definition i include the rcp delta pack AND some own
plugins. These own plugins are mainly wrapping a library and have
additionally rcp classes.
To use these plugins in my target definition i do an export of the plugins
(Export-> PDE -> deployable plugins) and deploy it into an special folder
of my workspace. These folder(s) i have added to my target definitnion
file.
Now the problem:
First try: When i export these plugins as jar's (and set the target
definition for my workspace), then the eclipse compiler moans, that he
cannot find the classes of the wrapped library inside the plugin.jar. (My
workspace is getting red due to of missing library classes)
Second try: But when i export these plugins as pure directory (not jar'ed)
the eclipse compiler finds the classes inside the wrapped jar, but i'm
getting problem when doing an product export of my whole project. The
Product Export (or ant build) now doesn't find the plugin classes of the
deployed plugins!
The ant build of my product log these failures:
[javac] The import com.xyz.my.deployed.plugin.rcp cannot be resolved
Summary:
exporting my library wrapping plugins as jar -> the eclipse compiler
doesn't find the classes of the jar's inside the plugin
exporting my library wrapping plugins as directory -> running the product
build by build.xml --> the javac-compiler doesn't find the wrapping plugin
classes.
What can i do ?
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44713 is a reply to message #44649] Wed, 04 February 2009 05:24 Go to previous messageGo to next message
I follow you use this new folder (referenced by your target definition) as
a target platform in your workspace?
If that's right you have to set this folder also as a target platform in
your build. Set the property 'baseLocation' (in any way) when you start
the headless eclipse build to the folder you use in your target platform.
-Matthias
S.Schnabl wrote:
> Hello,
> file.
> Now the problem:
> deployed plugins!
> Summary:
> classes.
> What can i do ?
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44742 is a reply to message #44713] Wed, 04 February 2009 06:53 Go to previous messageGo to next message
Currently there we are not doing an headless build. I simply use the
genereated build.xml when you do right click on plugin.xml -> PDE Tools ->
Create Ant Build File.
Is there a way to tweak the build.xml file ? Or must i define this
property explicitly in the build.properties tab ?
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44802 is a reply to message #44742] Wed, 04 February 2009 07:21 Go to previous messageGo to next message
If you run your build.xml in an eclipse you have to be sure your target
platform is set up correct ;)
When you generate an build.xml of a plugin it contains a @dot.classpath
(target @dot) where all required plugins and their paths are listed. Check
them and look for the path of the bundle which contains the package
'com.xyz.my.deployed.plugin.rcp'.
If everything is set up right check this bundle if the manifest is ok...
This is an example of a Manifest from a bundle which wrapps commons-lang:
Manifest-Version: 1.0
Bundle-Name: commons_lang
Bundle-ClassPath: lib/commons-lang.jar
Bundle-RequiredExecutionEnvironment: J2SE-1.4
Bundle-Vendor: rtc.ch
Bundle-ManifestVersion: 2
Bundle-SymbolicName: ch.rtc.rosi.commons_lang
Export-Package: org.apache.commons.lang,org.apache.commons.lang.builde
r,org.apache.commons.lang.enums,org.apache.commons.lang.exce ption,org
.apache.commons.lang.math,org.apache.commons.lang.mutable,or g.apache.
commons.lang.text,org.apache.commons.lang.time
Bundle-Version: 2.2.0.200902032205
The referenced path in @dot.classpath contains
'eclipse/plugins/ch.rtc.rosi.commons_lang_2.2.0.200902032205 /lib/commons-lang.jar'
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44828 is a reply to message #44802] Wed, 04 February 2009 07:42 Go to previous messageGo to next message
the @dot class path in build.xml looks like:
<pathelement path="../Deployed Plugins
Folder/plugins/com.xyz.my.deployed.plugin.rcp_2.1.10/@dot"/ >
Folder/plugins/com.xyz.my.deployed.plugin.rcp_2.1.10/lib/apa che/commons-math-1.2.jar "/>
Folder/plugins/com.xyz.my.deployed.plugin.rcp_2.1.10/lib/apa che/commons-codec-1.3.jar "/>
Also the bundle classpath in MANIFEST.MF looks ok:
Bundle-ClassPath: .,
lib/apache/commons-math-1.2.jar,
lib/apache/commons-codec-1.3.jar
I think that i correctly set the target platform (aka. definition). In my
Eclipse Workbench all is ok after setting the target platform.
Only the build (regardles of doing an .product-file build) or only by
build.xml fails with:
[javac] The import com.xyz.plugin.rcp cannot be resolved
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44858 is a reply to message #44828] Wed, 04 February 2009 08:25 Go to previous messageGo to next message
Could it be an absolute/relative path problem during build ? My own
deployed plugins are in an extra folder inside of my workspace and
referenced in the target definition file by:
<location path="${workspace_loc}\Deployed Plugins Folder"/>
In javaCompiler...args file i see (absolut?) entries like:
#ADAPTER#ACCESS#Deployed Plugins
Folder/plugins/com.xyz.plugin.rcp_2.1.10@dot[+com/xyz/plugin/rcp/*;+com/xyz/plugin/rcp/common
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44887 is a reply to message #44828] Wed, 04 February 2009 08:27 Go to previous messageGo to next message
I see your problem; your plugin com.xyz.my.deployed.plugin.rcp_2.1.10
contains additional jars and your own code.
Take the build.properties of the com.xyz.my.deployed.plugin.rcp plugin and
add the following:
bin.includes = META-INF/,\
commons-codec-1.3.jar,\
source.com.xyz.my.deployed.plugin.rcp.jar = src
(where 'src' must be your source directory which contains your own code.
This must create an additional jar with your code.)
Manifest:
Bundle-ClassPath: commons-codec-1.3.jar,
Export the plugin com.xyz.my.deployed.plugin.rcp again in your Deployed
Plugins Folder; generate the build.xml once again. Now the line
Folder/plugins/com.xyz.my.deployed.plugin.rcp_2.1.10/@dot"/ > will look
like <pathelement path="../Deployed Plugins
Folder/plugins/com.xyz.my.deployed.plugin.rcp_2.1.10/com.xyz .my.deployed.plugin.rcp.jar "/>
hopefully that's the solution ;)
Re: Target Definition and deployed plugins = class path problem in build.xml [message #44901 is a reply to message #44887] Wed, 04 February 2009 09:31 Go to previous messageGo to next message
Yeah, great. That works ! But i didn't really understand why ;-)
Please explain me, what we are doing here - i can only see, that an
additionally jar consisting my classes has been created.
Re: Target Definition and deployed plugins = class path problem in build.xml [message #45165 is a reply to message #44901] Thu, 05 February 2009 02:04 Go to previous messageGo to next message
If you generate an build.xml he asumes that if you require a bundle which
exists as a folder and contains source that he can build this bundle and
reference the '@dot' folder.
BUT you already have build this bundle and it only contains .class files
and these .jar's. So there is no @dot folder.
And unnoted by that fact it's good practise to pack .class files in a jar
;-) not in a folder.
Re: Target Definition and deployed plugins = class path problem in build.xml [message #45222 is a reply to message #45165] Thu, 05 February 2009 02:56 Go to previous message
Yes indeed ;-) But i run into compile errors when i deployed the plugins
as jars into the workspace. The workspace/compiler didn't find classes
which are in nested jars inside the plugin.jar's.
As a workaround i deployed my plugins as folder into the workspace.
Don't know, why it's not bad when deploying as jar with nested jars. Could
it be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=157375 ?
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591301 is a reply to message #44649] Wed, 04 February 2009 05:24 Go to previous message
-Matthias
S.Schnabl wrote:
> Hello,
> file.
> Now the problem:
> deployed plugins!
> Summary:
> classes.
> What can i do ?
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591309 is a reply to message #44713] Wed, 04 February 2009 06:53 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591322 is a reply to message #44742] Wed, 04 February 2009 07:21 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591328 is a reply to message #44802] Wed, 04 February 2009 07:42 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591333 is a reply to message #44828] Wed, 04 February 2009 08:25 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591341 is a reply to message #44828] Wed, 04 February 2009 08:27 Go to previous message
add the following:
Manifest:
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591349 is a reply to message #44887] Wed, 04 February 2009 09:31 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591450 is a reply to message #44901] Thu, 05 February 2009 02:04 Go to previous message
Re: Target Definition and deployed plugins = class path problem in build.xml [message #591465 is a reply to message #45165] Thu, 05 February 2009 02:56 Go to previous message
Previous Topic:How to create config.ini file to accept any eclipse plugins in my rcp
Next Topic:Can I use ant build rcp product?Anybody has correct example?
Current Time: Fri Nov 14 03:46:31 EST 2025
Powered by FUDForum. Page generated in 0.05889 seconds
