Home » Eclipse Projects » Nebula » Re: Using Nebula CalendarCombo and DataBinding
Re: Using Nebula CalendarCombo and DataBinding [message #44541] Wed, 05 December 2007 13:44
You might get more response on the eclipse.technology.nebula newsgroup,
which I've copied on this response.
Eric
Marcus Ilgner wrote:
> Hello group,
> on my search for a control providing a calendar selector to choose a
> date, I came upon the Nebula CalendarCombo and I like it very much:
> looks good, feels good.
> Since it is based upon a normal SWT Combo control, I was hoping that I
> could use the standard databinding SWTObservables.observeText(Control)
> method. However it does not seem to work and I was wondering if someone
> else has (or had) a similar problem.
> I was thinking that this should be a fairly common use case: binding
> dates to a UI control and letting the user choose a date via a calendar
> popup.
> Imo this is a topic that should be included on the Wiki.
> If noone has had any success on this, I will probably extend
> CalendarCombo with some PropertyChangeListener support myself and
> implement a CalendarComboObservableValue.
> Any comments on/against this? Should I open a ticket on the bugtracker
> concerning this issue?
> Best regards
> Marcus
Previous Topic:GridTableViewer - CellModifier problem with collapsed GridColumnGroup?
Next Topic:Re: Using Nebula CalendarCombo and DataBinding
Current Time: Mon Oct 27 02:47:35 EDT 2025
Powered by FUDForum. Page generated in 0.06252 seconds
