Home » Archived » M2M (model-to-model transformation) » Enumeration problem
Enumeration problem [message #44485] Tue, 05 June 2007 07:04 Go to next message
Originally posted by: bch.openbluelab.org
I have an enumeration with the literal "String" and I want test it whith :
if self.typ = #String then
But I have a syntax error. Do you know why ?
Re: Enumeration problem [message #44516 is a reply to message #44485] Tue, 05 June 2007 07:46 Go to previous messageGo to next message
Originally posted by: rchevrel.sodius.com
Hi Benjamin,
String is a reserved keyword. Use double-quote (#"String") or change
your literal name (prefix with "_" for example).
Régis (rchevrel /<at>/ sodius.com)
www.mdworkbench.com
Benjamin CHEVALLEREAU a écrit :
> whith :
> Thanks
Re: Enumeration problem [message #44547 is a reply to message #44516] Tue, 05 June 2007 08:22 Go to previous message
Régis a écrit :
> Hi Benjamin,
> www.mdworkbench.com
>> whith :
>> Thanks
Previous Topic:[ATL] Problem with latest run configuration ui
Next Topic:[ATL] XML2BPEL
Current Time: Thu Nov 06 05:04:20 EST 2025
Powered by FUDForum. Page generated in 0.04531 seconds
