| Logic Editor Example [message #44423] |
Thu, 21 November 2002 10:41  |
Originally posted by: sy_cheung2.yahoo.com
I am using Eclipse 20021119 with GEF build 20021119 and logic editor
20021114, but I can't get that to work.
The logic editor load successfully, but when i click a component (e.g. Or
GATE) and click on the graphics pane, it does not show up.
Do I need a different combination for my setting?
Thanks.
| Re: Logic Editor Example [message #45031 is a reply to message #44642] |
Fri, 22 November 2002 13:50  |
Originally posted by: hudsonr.us.eye-bee-em.com
Isn't this the same question as above?
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:arjnkv$q3d$1@rogue.oti.com...
> Is it possible to have one creation tool to support both way? The new
> Drag-and-drop way and the old "Select and Click" Way
> "Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
> news:ariv9c$akn$1@rogue.oti.com...
> > The other way (using the CreationTool) will still work. The And Gate
> you're
> > talking about does this. It's only there for testing purposes.
> > Eric
> > news:ariukp$a4k$1@rogue.oti.com...
> > > Okay, I am going to try that. Does that mean the GEF plugin I develop
> with
> > > an older version of GEF (0821) will no longer work?
> > > Also why there is an AND gate icon under the Connection icon in the
> logic
> > > Editor example now? I don't recall I see that in the older version of
> the
> > > Logic Editor Example.
> > > news:ariuak$9ph$1@rogue.oti.com...
> > > > Are you trying to create an Or Gate (for example)? I'm not sure
what
> > > version of
> > > > the logic example you were using before, but now it's using drag and
> drop
> > > from
> > > > the palette for creation. Drag a component from the palette and
drop
> it
> > > on the
> > > > editor to create that component.
> > > > Eric
> > > > news:arislb$8av$1@rogue.oti.com...
editor
> (e.g.
> > > Or
> > > > > Thanks.
FUDForum. Page generated in 0.04268 seconds
