Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44710 is a reply to message #44370] |
Thu, 24 July 2008 14:06  |
Michael,
Sorry for the delay in my response. We've pretty much stopped updating
this OHF Bridge installation due to the fact the server is quite
unreliable and combined with the fact that users of the OHF Bridge must
use it in their local environment at Connectathon. Sorry for the
references to the site in our documentation, we haven't been very
diligent in our updates of docs :)
As for running it in your local environment, it's very straightforward
to download and run locally. See:
http://www.eclipse.org/ohf/components/bridge/install.php
-Matt
Sarah Knoop wrote:
> Hi Michael,
> Sorry for the delay - I'm away on business. I'll have my colleague dig
> into this when he returns from vacation on WEds. Sorry for the delay.
> - Sarah
> Michael Sprinzl wrote:
>> Hi Sarah,
>> any updates regarding the status of the OHF Bridge? I just tried again
>> it noticed that it still seems to be down...
>> Kind regards
>> Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #585989 is a reply to message #44056] |
Wed, 16 July 2008 18:56  |
Hi Micheal -
You've reached the right forum here. We'll look into this - we had a
site shut down recently -- probably nothing more than re-starting Tomcat
or something.
- Sarah
> Hi everyone!
> I am new to the Eclipse OHF project and therefore I wanted to try the
> Public Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/
> mentioned in the OHF Wiki. After entering username & password I always get:
> Unknown error in getProxyohfsoapclient Object ( [bridgeClient] =>
> soap_fault Object ( [error_message_prefix] => [mode] => 1 [level] =>
> 1024 [code] => WSDLCACHE [message] => Unable to retrieve WSDL
> http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl,
> [userinfo] =>
> [backtrace] => Array ( [0] => Array ( [file] =>
> /usr/share/pear/SOAP/Fault.php [line] => 52 [function] => pear_error
> [class] => pear_error [type] => :: [args] => Array ( [0] => Unable to
> retrieve WSDL
> [1] => WSDLCACHE [2] => [3] => [4] =>
> http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl )
> ) [1] => Array ( [file] => /usr/share/pear/SOAP/Base.php [line] => 205
> [function] => soap_fault [class] => soap_fault [type] => -> [args] =>
> Array ( [0] => Unable to retrieve WSDL
> [4] => [5] => ) ) [2] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php
> [line] => 993 [function] => _raisesoapfault [class] => soap_wsdl_cache
> [type] => -> [args] => Array ( [0] => Unable to retrieve WSDL
> [1] =>
> ) [3] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 1067
> [function] => get [class] => soap_wsdl_cache [type] => -> [args] =>
> Array ( [0] =>
> [1] => Array ( ) ) ) [4] => Array ( [file] =>
> /usr/share/pear/SOAP/WSDL.php [line] => 1061 [function] => parse [class]
> => soap_wsdl_parser [type] => -> [args] => Array ( [0] =>
> ) [5] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 156
> [function] => soap_wsdl_parser [class] => soap_wsdl_parser [type] => ->
> [1] => soap_wsdl Object ( [_XMLSchema] => Array ( [0] =>
> http://www.w3.org/2001/XMLSchema [1] => http://www.w3.org/1999/XMLSchema
> ) [_XMLSchemaVersion] => http://www.w3.org/2001/XMLSchema [_typemap] =>
> Array ( [http://www.w3.org/2001/XMLSchema] => Array ( [string] => string
> [boolean] => boolean [float] => float [double] => float [decimal] =>
> float [duration] => integer [dateTime] => string [time] => string [date]
> => string [gYearMonth] => integer [gYear] => integer [gMonthDay] =>
> integer [gDay] => integer [gMonth] => integer [hexBinary] => string
> [base64Binary] => string [normalizedString] => string [token] => string
> [language] => string [NMTOKEN] => string [NMTOKENS] => string [Name] =>
> string [NCName] => string [ID] => string [IDREF] => string [IDREFS] =>
> string [ENTITY] => string [ENTITIES] => string [integer] => integer
> [nonPositiveInteger] => integer [negativeInteger] => integer [long] =>
> integer [int] => integer [short] => integer [byte] => string
> [nonNegativeInteger] => integer [unsignedLong] => integer [unsignedInt]
> => integer [unsignedShort] => integer [unsignedByte] => integer
> [positiveInteger] => integer [anyType] => string [anyURI] => string
> [QName] => string ) [http://www.w3.org/1999/XMLSchema] => Array ( [i4]
> => integer [int] => integer [boolean] => boolean [string] => string
> [double] => float [float] => float [dateTime] => string [timeInstant] =>
> string [base64Binary] => string [base64] => string [ur-type] => string )
> [http://schemas.xmlsoap.org/soap/encoding/] => Array ( [base64] =>
> string [array] => array [Array] => array [Struct] => array ) )
> [_defaultObjectClassname] => stdClass [_namespaces] => Array (
> [http://schemas.xmlsoap.org/soap/envelope/] => SOAP-ENV
> [http://www.w3.org/2001/XMLSchema] => xsd
> [http://www.w3.org/2001/XMLSchema-instance] => xsi
> [http://schemas.xmlsoap.org/soap/encoding/] => SOAP-ENC ) [_namespace]
> => [_xmlEntities] => Array ( [&] => & [<] => < [>] => > ['] => '
> ["] => " ) [_doconversion] => [__attachments] => Array ( ) [_wsdl] =>
> [_section5] => 1 [_auto_translation] => [_type_translation] => Array ( )
> [_debug_flag] => [_debug_data] => [_encodings] => Array ( [0] =>
> ISO-8859-1 [1] => US-ASCII [2] => UTF-8 ) [_myfaultcode] => WSDL [fault]
> => soap_fault Object ( [error_message_prefix] => [mode] => 1 [level] =>
> [userinfo] =>
> [backtrace] => Array *RECURSION* [callback] => ) [_debug] =>
> [_default_error_mode] => [_default_error_options] =>
> [_default_error_handler] => [_error_class] => SOAP_Fault
> [_expected_errors] => Array ( ) [tns] => [definition] => Array ( )
> [namespaces] => Array ( ) [ns] => Array ( ) [xsd] =>
> http://www.w3.org/2001/XMLSchema [complexTypes] => Array ( ) [elements]
> => Array ( ) [messages] => Array ( ) [portTypes] => Array ( ) [bindings]
> => Array ( ) [imports] => Array ( ) [services] => Array ( ) [service] =>
> [uri] =>
> [docs] => [proxy] => Array ( ) [trace] => 0 [cacheUse] => 0
> [cacheMaxAge] => 43200 [wsdlParserClass] => SOAP_WSDL_Parser ) [2] => )
> ) [6] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 125
> [function] => parseurl [class] => soap_wsdl [type] => -> [args] => Array
> ( [0] =>
> ) [7] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line]
> => 38 [function] => soap_wsdl [class] => soap_wsdl [type] => -> [args]
> => Array ( [0] =>
> ) [8] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line]
> => 25 [function] => initbridgeservice [class] => ohfsoapclient [type] =>
> -> [args] => Array ( ) ) [9] => Array ( [file] =>
> /healthcare/demo/lib/OHFRhioConfigurations.php [line] => 50 [function]
> => ohfsoapclient [class] => ohfsoapclient [type] => -> [args] => Array (
> [0] => Array ( [user] => asas [password] => asas [facility] => ) [1] =>
> utils Object ( ) ) ) [10] => Array ( [file] =>
> /healthcare/demo/lib/OHFRhioConfigurations.php [line] => 42 [function]
> => showrhiopanel [class] => ohfrhioconfigurations [type] => -> [args] =>
> Array ( [0] => Array ( [user] => asas [password] => asas [facility] => )
> [1] => utils Object ( ) ) ) [11] => Array ( [file] =>
> /healthcare/demo/index.php [line] => 55 [function] => isconfigured
> [class] => ohfrhioconfigurations [type] => -> [args] => Array ( [0] =>
> Array ( [logout] => no [badlog] => no [getMyLog] => no [reset_rhio] =>
> no [search_patient] => no [add_patient_form] => no [search_doc_by_id] =>
> no [search_doc_by_details] => no [search_doc_do_search] => no
> [searchPatientId] => [AANamespaceId] => [AAUniversalId] =>
> [AAUniversalIdType] => [AAUniversalIdTypeCode] => [patientIdx] =>
> [patient_details] => no [patientId] => [idNumber] => [patientId2send2]
> => [sendDocument] => no [useFQS] => off [user] => asas [password] =>
> asas [facility] => ) [1] => Array ( [user] => asas [password] => asas
> [facility] => ) [2] => utils Object ( ) ) ) ) [callback] => ) [utils] =>
> utils Object ( ) [_SESSION] => Array ( [user] => asas [password] => asas
> [facility] => ) ) The OHF Bridge is probably down.
> I tried to send a mail to Eishay Smith as mentioned within the error
> message but it returned, mainly due to the fact that Eishay does not
> work anymore for IBM Almaden Research Center (according to Google ;-)).
> Any ideas who I should contact regarding this issue or is the Public
> Demo OHF Bridge not maintained anymore?
> Kind regards
> Michael Sprinzl
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #586112 is a reply to message #44223] |
Mon, 21 July 2008 11:30  |
Hi Michael,
- Sarah
> Hi Sarah,
> Kind regards
> Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #586266 is a reply to message #44370] |
Michael,
-Matt
Sarah Knoop wrote:
> Hi Michael,
> - Sarah
>> Hi Sarah,
>> Kind regards
>> Michael
FUDForum. Page generated in 0.29395 seconds
