Home » Newcomers » Newcomers » Properties
Properties [message #44009] Thu, 31 March 2005 05:26 Go to next message
Originally posted by: lusp.21cn.com
When use eclpise to create a visual class en error occured! "Properties" tab
page display nothing,except"An error occured while creating properties."
Why?
And how can i to solved this problem?
any one help me! many thanks!
Sean Lu
Re: Properties [message #44346 is a reply to message #44009] Thu, 31 March 2005 09:37 Go to previous message
Are you working on an existing visual class or a completely new class?
What version of Eclipse and VE are you using? You may want to make sure you
are using compatable versions of the two and their corresponding related
components.
You might want to look in the log file which is contained in your workspace
directory in the .metadata subdirectory which may provide some additional
insight into the problem.
Eric
"Sean" <lusp@21cn.com> wrote in message
news:d2gjbs$3in$1@news.eclipse.org...
tab
> Why?
> Sean Lu
Previous Topic:Creating .exe from Java code
Next Topic:Debug with -D param
Current Time: Wed Nov 05 04:48:01 EST 2025
Powered by FUDForum. Page generated in 0.08804 seconds
