Home » Eclipse Projects » Eclipse Platform » [CVS] modify multiple branches
[CVS] modify multiple branches [message #43985] Thu, 22 May 2003 12:23 Go to next message
Originally posted by: patjlm.hotmail.com
Is there an easy way to do a change in several branches at the same time.
Say, we have branch1, branch2 and HEAD.
We modify some source files in branch1 and want to report the changes in
branch2 and HEAD.
I see that there is a merge option. But it does not seem to report only my
changes, but all changes (from all developers) since the beginning of the
branch.
There is also the patch option (create a patch before commiting, and
applying this patch in all subsequent branches). But I am not sure how safe
/ easy it is.
Any input appreciated.
Patrick.
Re: [CVS] modify multiple branches [message #45342 is a reply to message #43985] Fri, 23 May 2003 08:31 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
You can make a patch of your changes before checkin and apply it to the
other branch(es).
robert
"Patrick Martin" <patjlm@hotmail.com> schrieb im Newsbeitrag
news:baitir$th3$1@rogue.oti.com...
time.
> branch2 and HEAD.
my
the
> branch.
safe
> / easy it is.
> Patrick.
Re: [CVS] modify multiple branches [message #45395 is a reply to message #45342] Fri, 23 May 2003 08:44 Go to previous messageGo to next message
Thanks for your answer,
Is that the only way?
Or is it possible to have eclipse check stuff just before commiting?
My idea would be that when a developer chooses to commit one or several
files in a branch, eclipse could realize it and offer to create a patch, or
even to try to apply this patch in an other branch.
Would this be possible? Did anyone have an experience with this kind of
things?
Thank you,
Patrick
"Robert Klemme" <bob.news@gmx.net> wrote in message
news:bal4dt$h5k$1@rogue.oti.com...
> other branch(es).
> robert
> > Hi,
> time.
> > branch2 and HEAD.
> my
> the
> > branch.
> safe
> > / easy it is.
> > Thanks,
> > Patrick.
Re: [CVS] modify multiple branches [message #46340 is a reply to message #45395] Fri, 23 May 2003 12:37 Go to previous messageGo to next message
news:bal53s$hl3$1@rogue.oti.com...
or
That's a very specialized application of patches. You normally don't
commit the same change on several branches. If you have to, you should
reconsider the way you work with CVS - or maybe get another SCCS.
> things?
It certainly would be possible to do that. But I doubt that it has a
change being realized. IMHO it's too special. You *have* the option to
create branches in CVS because you want to separate development
activities. By automatically commiting changes from one branch to another
the whole concept of branches is questionable...
robert
> Thank you,
> Patrick
the
> > other branch(es).
> > robert
> > > Hi,
> > time.
changes in
> > > branch2 and HEAD.
only
> > my
of
> > the
> > > branch.
how
> > safe
> > > / easy it is.
> > > Thanks,
> > > Patrick.
Re: [CVS] modify multiple branches [message #46491 is a reply to message #46340] Fri, 23 May 2003 13:41 Go to previous messageGo to next message
[snip]
I have to disagree. A common use of branching is when a product/project
has a release point - you label and branch at the release point in order
to have maintenance of that release and new development for the next
release happen in parallel. If a bug is found and fixed on the
maintenance branch, it is likely the same fix will need to be applied to
the HEAD so the next version does not resurrect the bug.
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: [CVS] modify multiple branches [message #47198 is a reply to message #46491] Sat, 24 May 2003 04:04 Go to previous messageGo to next message
>> don't commit the same change on several branches. If you have
>> to, you should reconsider the way you work with CVS - or maybe
>> get another SCCS.
> [snip]
>> has a change being realized. IMHO it's too special. You
>> *have* the option to create branches in CVS because you want to
>> separate development activities. By automatically commiting
>> changes from one branch to another the whole concept of
> product/project has a release point - you label and branch at
> the release point in order to have maintenance of that release
> and new development for the next release happen in parallel. If
> a bug is found and fixed on the maintenance branch, it is likely
> the same fix will need to be applied to the HEAD so the next
OK, but on my CVS I have two separate versions of a simulation
program that shouldn't mangle changes because they handle slightly
different problems.
In any case, the multiple branch committing should remain a non-
default option IMHO.
Wald
Re: [CVS] modify multiple branches [message #47729 is a reply to message #47198] Mon, 26 May 2003 03:11 Go to previous messageGo to next message
I agree that it should no be a default. It is a specific matter.
However, I am sure many team work this way (having branches for maintenance
releases and having to commit some fixes in several branches).
I don't know anything in plugin developments in Eclipse. Is it hard to
optionnaly insert a check in the commit action? This check would see if the
commit is being performed in a branch and automatically offer to generate a
cvs patch.
Patrick.
"Wald" <arnout.standaert@n-o-s-p-a-m.cit.kuleuven.ac.be> wrote in message
news:Xns9385668CD2D35arnoutstandaertagrku@204.138.98.10...
> >> get another SCCS.
> > [snip]
> different problems.
> Wald
Re: [CVS] modify multiple branches [message #47887 is a reply to message #46491] Mon, 26 May 2003 05:33 Go to previous messageGo to next message
"Eric Rizzo" <eric.rizzo@jibeinc.com> schrieb im Newsbeitrag
news:balmld$219$1@rogue.oti.com...
should
> [snip]
to
another
Sounds reasonable. Maybe then better file a feature request for this.
robert
Re: [CVS] modify multiple branches [message #48006 is a reply to message #47887] Mon, 26 May 2003 06:48 Go to previous message
I created #38042 for that. Anybody welcome to vote and comment.
However, I'd like to try to work on a plugin that would do that (so it is
available before the next stable release). The problem is that I don't know
anything (yet) about plugins. For example, how does one catch the "cvs
commit" event?
Patrick.
news:basnla$of2$1@rogue.oti.com...
> should
> > [snip]
> to
> another
> robert
Previous Topic:some problem in getting a file from Project or some Folder
Next Topic:[ANN] metrics release 1.2.0 available
Current Time: Wed Nov 12 13:43:12 EST 2025
Powered by FUDForum. Page generated in 0.26544 seconds
