Home » Archived » GEF3D » 2.5 D update example
2.5 D update example [message #3823] Sun, 31 May 2009 19:21 Go to next message
This is just a proof of concept -- the shapes are ugly and it isn't
really optimized..but really good performance still.
http://metascapeabm.com/presentations/Eclipse3D.mov
Re: 2.5 D update example [message #3843 is a reply to message #3823] Mon, 01 June 2009 13:29 Go to previous messageGo to next message
In this example, as you can see there are ony two faces being drawn for
each cube, not the whole cube. I'm just using SolidCube here, and
setting a color. Do I need to be specifiying a texture as well?
Re: 2.5 D update example [message #3850 is a reply to message #3843] Mon, 01 June 2009 14:22 Go to previous message
Hi Miles,
Cool ;-) Frankly, I do not really understand what these boxes are doing
there, but it looks quite well.
No, this is a GEF3D bug, actually I knew about that bug but then I did
forget it. I added a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278651
and fixed it (at least I hope so, otherwise change the bug report ;-)
). You would like to update org.eclipse.draw3d.shapes.SolidCube (rev.
146).
Jens
Re: 2.5 D update example [message #561718 is a reply to message #3823] Mon, 01 June 2009 13:29 Go to previous message
Re: 2.5 D update example [message #561732 is a reply to message #3843] Mon, 01 June 2009 14:22 Go to previous message
Hi Miles,
146).
Jens
Previous Topic:A couple of errors in ..draw3d
Next Topic:Specifying Camera Location Programmatically...
Current Time: Sun Nov 02 22:43:50 EST 2025
Powered by FUDForum. Page generated in 0.25639 seconds
