Home » Eclipse Projects » Eclipse Platform » ResourceBundle, and need the file path as a String
ResourceBundle, and need the file path as a String [message #43954] Thu, 22 May 2003 12:09 Go to next message
Originally posted by: mouse7m.hotmail.com
I have a ResourceBundle, and need it's file path as a String. how can i do
this in Eclipse plug-in entwicklung? am best is an example. thanks.
Filix
Re: ResourceBundle, and need the file path as a String [message #44231 is a reply to message #43954] Thu, 22 May 2003 13:08 Go to previous messageGo to next message
Originally posted by: olivier_thomann.nospam.oti.com
On Thu, 22 May 2003 16:09:30 +0000 (UTC), mouse7m@hotmail.com (Filix)
It doesn't need its path, it simply needs its fully qualified name. As
long as you put the .properties file in the classpath, it should work.
For example:
ResourceBundle.getBundle("org.eclipse.jdt.internal.antadapter.messages ",
Locale.getDefault());
will try to load the file messages.properties located in the package
org.eclipse.jdt.internal.antadapter. If this package is on the
classpath and the messages.properties is inside this package, then it
should be found. You can have multiple messages_xx_xx.properties files
to handle different locales.
Olivier
Re: ResourceBundle, and need the file path as a String [message #44289 is a reply to message #44231] Thu, 22 May 2003 13:22 Go to previous messageGo to next message
> It doesn\'t need its path, it simply needs its fully qualified name. As
> For example:
> ResourceBundle.getBundle(\"org.eclipse.jdt.internal.antadapter.messages\ ",
> Olivier
thank you, but if I want to create another file in the same directory, i
still need to get out its path, or there is any other way to do this?
Felix
Re: ResourceBundle, and need the file path as a String [message #44319 is a reply to message #44289] Thu, 22 May 2003 13:38 Go to previous message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Thu, 22 May 2003 17:22:24 +0000 (UTC), mouse7m@hotmail.com (Felix)
Why do you need to create a file in the same directory and use it with
a resource bundle?
Please describe what you are trying to do.
Olivier
Previous Topic:Image display/information view available?
Next Topic:Umlauts in files get lost under linux
Current Time: Tue Nov 04 21:14:05 EST 2025
Powered by FUDForum. Page generated in 0.03267 seconds
