Home » Language IDEs » ServerTools (WTP) » XML editor DTD resolver
XML editor DTD resolver [message #43858] Mon, 13 September 2004 16:05 Go to next message
Hello all,
I'm trying to edit hibernate's configuration file (hibernate.cfg.xml)
with WTP's XML editor. Here is the DOCTYPE declaration of this file:
<!DOCTYPE hibernate-configuration PUBLIC
"-//Hibernate/Hibernate Configuration DTD//EN"
" http://hibernate.sourceforge.net/hibernate-configuration-3.0 .dtd">
XML editor is trying to retrieve the DTD file from the net. But, since
there is a proxy server in our local network it can't access the DTD file.
I edited settings in Preferences -> Internet to specify the proxy server
we're using (btw, it is Microsoft's ISA server). It didn't work.
Then, I downloaded the DTD to a local folder and added an entry in
Preferences -> Web and XML -> XML Catalog. I thought it didn't work either.
Each time there was an error marker at the line of DOCTYPE declaration
saying "the server returned: forbidden 403 you can't access the
resource...".
I was sure, it had to work for the latter case, and, removed the
contents of the hibernate config file (hibernate.cfg.xml) and re-added.
And.. it worked! :-)
So here are my questions..
* Am I doing something wrong or is it a bug?
* Where can I specify the proxy server/port along with username/password
information for XML editor? I don't want to add a *local* DTD in XML
Catalog for every XML file with a DOCTYPE declaration I'm editing.
Thanks.
Re: XML editor DTD resolver [message #44130 is a reply to message #43858] Tue, 14 September 2004 21:54 Go to previous message
Bug (2 of them).
The proxy in the internet preferences should have worked. Not sure why it
didn't but in your
case, but have heard someone mention there is sometimes a conflict with
update manager.
The second bug sounds like the task/marker/error isn't being cleaned up
properly.
BTW, which platform are you on? (be sure to report that when you report
the bugs :)
I have a vague memory that windows and linux treats the proxy settings
differently, so just
wondering if that's a variable here.
Previous Topic:Web service: Tomcat 5.0 will show up in the list of available servers
Next Topic:how to disable jsp search in IBM contribution
Current Time: Sat Nov 22 08:10:16 EST 2025
Powered by FUDForum. Page generated in 0.11750 seconds
