Home » Eclipse Projects » Nebula » Nebula Grid Widget
Nebula Grid Widget [message #43836] Thu, 22 November 2007 10:53 Go to next message
Originally posted by: kwinter1.gmx.de
Hi all,
while looking at the Grid Widget I've got some questions:
- The first question is about the alpha status of this widget. Is it
recommended to be used in production code?
- I haven't found some kind of roadmap about how and when things are
progressing. When is it going to be marked as stable (or merged to SWT)?
- Is there a similar performance issue with large number of root items as
with the SWT Tree in Windows?
Klaus
Re: Nebula Grid Widget [message #43899 is a reply to message #43836] Mon, 26 November 2007 14:52 Go to previous message
Hi Klaus,
The Grid is very stable and is in use in production code. The primary
reason its still marked as ALPHA is because the API is not set in stone.
I have not published a roadmap because 1.) I'd probably not be able to
fulfill any promises I made 2.) the community has been very good at
providing patches for new Grid features and any roadmap I would provide
wouldnt be complete w/o taking those into account. I hope to complete
Grid 1.0 to coincide with 3.4, but like I said its very stable right now.
Re performance issues, I don't know what performance issue you are
referring to but I would suggest you test Grid yourself. The Windows
Table and Tree are generally pretty fast (are you using SWT.VIRTUAL?).
Grid is not quite as fast as Table (not sure about Tree) just yet.
-Chris
Klaus Winter wrote:
> Hi all,
> Cheers,
> Klaus
Re: Nebula Grid Widget [message #586612 is a reply to message #43836] Mon, 26 November 2007 14:52 Go to previous message
Hi Klaus,
-Chris
Klaus Winter wrote:
> Hi all,
> Cheers,
> Klaus
Previous Topic:Nebula Grid Widget
Next Topic:SWT Ribbon any alpha release ?
Current Time: Thu Nov 27 20:43:41 EST 2025
Powered by FUDForum. Page generated in 0.04339 seconds
