| 1.2.0M1 showing error msg (MAJOR bug possibly) [message #43758] |
Tue, 02 November 2004 09:24  |
Hi. This is the first time i am using ajdt.
I downloaded the 1.2.0M1 release and unzipped it into my eclipse directory.
But now whenever i try to create a new AspectJ project it gives me an
error saying -
"The selected wizard could not be started.
Plug-in org.eclipse.adjt.ui was unable to load class
org.eclipse.ajdt.internal.ui.wizards.AspectJProjectWizard"
I have Eclipse 3.0 installed. A similar kind of error i get when trying to
access the adjt page in the preferences window.
Is this some kind of bug?
PRASHANT
| Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #44201 is a reply to message #43953] |
Wed, 10 November 2004 16:03  |
Well i have raised a bug report. Lets see if a solution can be found.
Matt Chapman wrote:
> On Wed, 03 Nov 2004 11:28:00 +0000, Prashant wrote:
>> Hi i got the solution.
>> You need to document your stuff better ;)
>> The above problem occurs only when you already have an existing workspace
>> and you try to create an AJDT project in it. But if you create an
>> altogether new workspace in a new directory, the problem goes away. The
>> same bug is in 1.1.12 also.
>> You need to specify on the download page to create a new workspace after
>> installing AJDT otherwise none of its components would work in an existing
>> workspace.
> Hi, I'm glad things are working for you now.
> We haven't documented this issue, because we've not been aware of it
> before. We have successfully installed AJDT with existing workspaces, as I
> believe others have too. But I don't know why it didn't work for you.
> Matt.
| Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #584666 is a reply to message #43758] |
Tue, 02 November 2004 11:43  |
On Tue, 02 Nov 2004 14:24:10 +0000, Prashant wrote:
> Hi. This is the first time i am using ajdt. I downloaded the 1.2.0M1
> error saying -
> PRASHANT
It sure looks like something has gone badly wrong for you. I've never
heard of it doing this for others. I suspect there is something incorrect
or unusual about your environment or setup. Please raise a bug report for
this, with as much detail as possible, and we'll pursue it there.
Matt.
| Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #584696 is a reply to message #43771] |
Wed, 03 November 2004 06:28  |
The same bug is in 1.1.12 also.
workspace.
PRASHANT
>> error saying -
>> PRASHANT
> Matt.
| Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #584775 is a reply to message #43832] |
Thu, 04 November 2004 09:55  |
> workspace.
Matt.
| Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #584901 is a reply to message #43953] |
>> workspace.
> Matt.
FUDForum. Page generated in 0.04533 seconds
