Home » Newcomers » Newcomers » Eclipse for amd64 startup problem in linux
Eclipse for amd64 startup problem in linux [message #43738] Wed, 30 March 2005 18:46
Originally posted by: xyphnite.email.arizona.edu
I run the command ./eclipse, and this is the error that is logged. I
checked that those files exist, and they do. Any suggestions as to how I
may fix this?
!SESSION Mar 31, 2005 16:32:56.523
eclipse.buildId=M200503110845
java.version=1.4.2_07
BootLoader constants: OS=linux, ARCH=amd64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Mar 31, 2005 16:32:56.526
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/home/xyphanite/eclipse/plugins/org.eclipse.swt.gtk64_3.0.2/ os/linux/amd64/libswt-pi-gtk-3064.so:
cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1495)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:268)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Previous Topic:Language pack not found wXP
Next Topic:where can i find the source code for eclipse 3.0 instead of api?
Current Time: Thu Nov 06 02:26:12 EST 2025
Powered by FUDForum. Page generated in 0.09508 seconds
