RAServer unable to find pthreads [message #43720] |
Tue, 29 November 2005 19:06  |
I'm unable to get RAServer to work on linux (RHEL, x86). I saw an earlier
discussion thread that didn't appear to come to a successful conclusion,
so here I am.
I'm assuming one is not able to just ignore the pthreads message, because
I'm not able to see any agents on the remote host (although I am able to
successfully test connect on port 10002)
When I run RAServer i get:
Could not find the pthread library (2).Are you running a supported Linux
distribution ?RAServer started successfully
running ldd RAServer:
ldd RAServer
/lib/libcwait.so => /lib/libcwait.so (0xb75e5000)
libpthread.so.0 => /lib/tls/libpthread.so.0 (0xb75d5000)
libdl.so.2 => /lib/libdl.so.2 (0xb75d2000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0xb75a5000)
libxerces-c.so.24 => /d000/home/profit/tptp/lib/libxerces-c.so.24
(0xb7156000)
libcbe.so => /d000/home/profit/tptp/lib/libcbe.so (0xb7136000)
libhcclco.so => /d000/home/profit/tptp/lib/libhcclco.so
(0xb712c000)
libhcclserc.so => /d000/home/profit/tptp/lib/libhcclserc.so
(0xb7110000)
libhcclsert.so => /d000/home/profit/tptp/lib/libhcclsert.so
(0xb710b000)
libhccls.so => /d000/home/profit/tptp/lib/libhccls.so (0xb7107000)
libhcclsm.so => /d000/home/profit/tptp/lib/libhcclsm.so
(0xb70fb000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0xb70b9000)
libm.so.6 => /lib/tls/libm.so.6 (0xb7096000)
libc.so.6 => /lib/tls/libc.so.6 (0xb6f5e000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0xb75e9000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb6f55000)
so ldd seems to indicate RAServer should be able to find libpthread.
My LD_LIBRARY_PATH is currently:
LD_LIBRARY_PATH=/usr/lib:/lib:/lib/tls:/lib/i686/::/d000/hom e/profit/tptp/bin/:/d000/home/profit/tptp/lib/
I'm using the BEA Jrockit VM, version below:
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_05-b04)
BEA WebLogic JRockit(TM) 1.4.2_05 JVM R24.4.0-1 (build
ari-38120-20041118-1131-linux-ia32, Native Threads, GC strategy: parallel)
Any ideas would be much appreciated!
Re: RAServer unable to find pthreads [message #45009 is a reply to message #44145] |
Mon, 05 December 2005 20:01  |
I notice performance degradation about two magnitudes slower - something
which would normally take 150ms can take 70s instead. I guess it's normal,
but I do think that TPTP generates an incredible amount of data.
Jevon
FUDForum. Page generated in 0.36651 seconds
