Home » Archived » BIRT » Create pie chart programatically?
Create pie chart programatically? [message #43709] Tue, 07 June 2005 07:30 Go to next message
Hello folks,
Eclipse Chart Engine seems promising for chartting with SWT.
Can anyone upload snippet for creating pie chart (2d with depth) with SWT
programatically?
I'd like to use pie chart within SWT application.
Thanks in advance.
Re: Create pie chart programatically? [message #43945 is a reply to message #43709] Tue, 07 June 2005 11:27 Go to previous messageGo to next message
Originally posted by: mpadhye.actuate.com
Take a look at the code to create a Line chart programmatically as
given in a separate thread in this group 'create a line chart
programmatically'.
Here is the code for creating a Pie chart programmatically. It is
loosely based on the code for the line chart so you can get a better
feel for the structural differences between these two chart types.
NOTE: It is also possible to take a look at how basic models for other
chart types are created if you have downloaded the code. The code for
the chart types resides in the org.eclipse.birt.chart.ui.extension
plug-in under the org.eclipse.birt.chart.ui.swt.type package. (Take a
look at the getModel() method in the various classes.
// Code Start
* Creates a pie chart model as a reference implementation
* @return An instance of a pie chart model (with sample data)
public static final Chart createSimplePieChart()
ChartWithoutAxes cwoaPie = ChartWithoutAxesImpl.create();
cwoaPie.setType("Pie Chart");
cwoaPie.setSubType("Standard Pie Chart");
cwoaPie.setDimension(ChartDimension.TWO_DIMENSIONAL_WITH_DEP TH_LITERAL);
cwoaPie.getBlock().setBackground(ColorDefinitionImpl.WHITE() );
Plot p = cwoaPie.getPlot();
p.getClientArea().setBackground(ColorDefinitionImpl.create(2 55,
255, 225));
cwoaPie.getTitle().getLabel().getCaption().setValue("Sample Pie
Chart");
Legend lg = cwoaPie.getLegend();
LineAttributes lia = lg.getOutline();
lg.getText().getFont().setSize(16);
lia.setStyle(LineStyle.SOLID_LITERAL);
lg.getInsets().set(10, 5, 0, 0);
lg.getOutline().setVisible(false);
lg.setAnchor(Anchor.NORTH_LITERAL);
// CREATE THE CATEGORY SERIES
Series seCategory = SeriesImpl.create();
// CREATE THE PRIMARY DATASET
PieSeries ls = (PieSeries) PieSeriesImpl.create();
ls.setSeriesIdentifier("My Pie Series");
ls.setSliceOutline(ColorDefinitionImpl.CREAM());
ls.getLabel().setVisible(true);
SeriesDefinition sdX = SeriesDefinitionImpl.create();
sdX.getSeriesPalette().update(0); // SET THE COLORS IN THE PALETTE
sdX.setQuery(QueryImpl.create(""));
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette().update(1); // SET THE COLORS IN THE PALETTE
sdY.setQuery(QueryImpl.create(""));
sdX.getSeriesDefinitions().add(sdY);
sdX.getSeries().add(seCategory);
sdY.getSeries().add(ls);
cwoaPie.getSeriesDefinitions().add(sdX);
addSampleData(cwoaPie);
return cwoaPie;
// Code End
Milind
jungcw@kr.ibm.com wrote:
> Hello folks,
> programatically?
> Thanks in advance.
Re: Create pie chart programatically? [message #685794 is a reply to message #43945] Mon, 20 June 2011 02:40 Go to previous message
hi Jung and Folks,
i want to create a PlugIn for Eclipse-Helios which draws a Piechart.
So i am using JFreeChart for SWT.
But when i create PlugIn and run as Eclipse application it is neither creates pie chart nor running and showing error like could not instantiate view. But i have added all the libraries. The problem is it is not able load the JFreechart libraries dynamically.
Could you explain why it is happening.
Thanks in advance.
kranti Kumar Ch
Previous Topic:SQL Query changes take long
Next Topic:Table footer for every page
Current Time: Sat Nov 22 06:01:34 EST 2025
Powered by FUDForum. Page generated in 0.03385 seconds
