| How do I upgrade from 2.0.2 to 2.1 M4? [message #43670] |
Sun, 26 January 2003 16:34  |
Originally posted by: dinkloh.ipd.uni-karlsruhe.de
Hello!
How can I upgrade from Eclipse 2.0.2 to 2.1 M4? Is it enough just to unzip
the corresponding files into the eclipse directory? I would like to preserve
my settings, but as I understand it, those are in the .metadata subdirectory
under the workspace directory and therefore should not be affected by the
upgrade, is that right?
Thank you for the help,
Martin
| Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #49336 is a reply to message #43762] |
Tue, 18 March 2003 15:44  |
Originally posted by: nospam.metaclass.nl
If you are building plugins, you may have to revise the class path and then
do "Organize Imports" to revise the import statements. (I tried to compile
the readmetool example version 2.0.2 with 2.1 M3, but got lots of errors,
all resulting from org.eclipse... classes being moved to differen packages.
Initally i missed some of the new packages in the class path, so "Organize
Imports" created import statements that import classes from javax.swing...
However after removing the errorneous import statements Eclipse was quite
quite good at finding where the classes had gone )
Henk Verhoeven,
MetaClass.
Jared Burns <jared-eclipse@mn.rr.com> wrote in message
news:b13vc8$hhk$2@rogue.oti.com...
> Just unzipping the new archive over your old install might work, but I
> wouldn't recommend it. You'd be better off deleting the old install and
> unzipping the new one fresh.
> If your workspace directory is in your Eclipse install location (the
default
> behavior, but not recommended), make sure to back it up first!
> - Jared
unzip
> > preserve my settings, but as I understand it, those are in the .metadata
> > subdirectory under the workspace directory and therefore should not be
> > affected by the upgrade, is that right?
| Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #589456 is a reply to message #43670] |
Mon, 27 January 2003 14:16  |
If your workspace directory is in your Eclipse install location (the default
- Jared
| Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #589469 is a reply to message #43762] |
Mon, 27 January 2003 17:59  |
Originally posted by: oshteynbuk.nyc.rr.com
in addition to what Jared said you can also check out swiki
http://eclipsewiki.swiki.net/131
or/and
there is an ant script to update
http://home.nyc.rr.com/olegs/
oleg
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
default
> - Jared
unzip
| Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #591692 is a reply to message #43762] |
Henk Verhoeven,
MetaClass.
default
> - Jared
unzip
FUDForum. Page generated in 0.04392 seconds
