| Providing Images [message #43657] |
Mon, 02 February 2009 05:33  |
i just realized that the swt group is actually a better place for this,
so here goes the cross-post.
As I got my plugin mostly working, now there is a desire for some sleek
looks. Thus, I need to add some images. I came across the interesting
article at
http://www.eclipse.org/articles/Article-Using%20Images%20In% 20Eclipse/Using%20Images%20In%20Eclipse.html
which mentions, that each AbstractUIPlugin has an ImageRegistry built-in
and all I need to do is initialize it.
However, attempting to do this yielded some trouble. I tried
initializing the ImageRegistry in
AbstractUIPlugin#initializeImageRegistry(ImageRegistry) as recommended
in the JavaDoc but got stuck when I discovered that ImageDescriptor is
abstract and no implementation is available.
There is an Implementation FileImageDescriptor, but its Package-Private.
Is there any reason for this? The class appears to be rather
straugt-forward, copying it to my own plugin showed no errors. Can this
class be made public?
Additionally, I gave some thought to this image-situation. Is there any
particular reason, why there is no extension point to add Images
declaratively to the platform ImageRegistry or at least the plugin
ImageRegistry? An ID, the plugin ID (in case of platform registry) and
the path within the plugin should be sufficient to be able to
automatically create an ImageDescriptor for every Image specified.
When implemented in
AbstractUIPlugin#initializeImageRegistry(ImageRegistry) this should not
break any existing functionality. Anyone wishing to use the new
extension point just has to add a call to super.
Specifying a few icons seems like a fairly common use-case, especially
since eclipse doesn't provide much of its own Icons. (Every once in a
while I come across a site offering all the current eclipse icons for
download and inclusion in custom plugins - most IDE-Icons are missing
from API).
Damian Philipp
| Re: Providing Images [message #43686 is a reply to message #43657] |
Mon, 02 February 2009 08:03   |
ImageDescriptor has some static methods to load images.
Tom
Damian Philipp schrieb:
> Hello,
> article at
> When implemented in
> from API).
> Regards
> Damian Philipp
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Providing Images [message #44061 is a reply to message #44029] |
Tue, 03 February 2009 04:09  |
You load the descriptor and put it into the registery you obtained
previously.
Tom
> Hello,
> Tom Schindl schrieb:
>> By the way you can easily load images using the
>> AbstractUIPlugin#imageDescriptorFromPlugin!
> judging from the JavaDoc, if I create images from ImageDescriptors
> obtained this way, I have to dispose of them myself. I was trying to
> avoid having to do that by using the ImageRegistry.
> Regards
> Damian Philipp
| Re: Providing Images [message #590976 is a reply to message #43657] |
Tom
> Hello,
> article at
> When implemented in
> from API).
> Regards
> Damian Philipp
| Re: Providing Images [message #591003 is a reply to message #43686] |
Mon, 02 February 2009 11:11  |
Whops, sorry. I should have seen that.
I still think that specifying images for the ImageResigtry declaratively
would be a good idea though.
Damian Philipp
| Re: Providing Images [message #591016 is a reply to message #43748] |
Mon, 02 February 2009 11:48  |
Tom
> Hello,
> Regards
> Damian Philipp
| Re: Providing Images [message #591099 is a reply to message #43748] |
Tue, 03 February 2009 00:52  |
There is a bug open already to add images to SharedImages thru plugin.xml.
Hopefully it should make it into 3.5 M6
- Prakash
http://blog.eclipse-tips.com
"Damian Philipp" <damian.philipp@flexis.de> wrote in message
news:gm75vg$nbq$1@build.eclipse.org...
> Hello,
> Regards
> Damian Philipp
| Re: Providing Images [message #591109 is a reply to message #43792] |
Tue, 03 February 2009 02:10  |
Damian Philipp
| Re: Providing Images [message #591114 is a reply to message #44029] |
previously.
Tom
> Hello,
> Regards
> Damian Philipp
FUDForum. Page generated in 0.07407 seconds
