Problems with Oracle JDBC data source [message #43582] |
Tue, 07 June 2005 02:46  |
Originally posted by: juergen.schwarz.gefasoft.de
I'm using BIRT 1.0 and cerated a datasource to an Oracle 9 database and
a new record set for a table in that DB.
In the record set settings box in BIRT everything works, I can see and
select the table columns, even the preview of the records is fine.
But in the report where I want to use these records, the preview does
not work but generates the following error message:
There are errors on the report page:Error1:Die Verbindung kann fьr
Treiber (org.eclipse.birt.report.data.oda.jdbc) nicht geцffnet
werden.Cannot load JDBC Driver class: [oracle.jdbc.OracleDriver]. Cannot
Sorry, BIRT display in German on my system.
Any help what the cause for this may be?
Juergen
Re: Problems with Oracle JDBC data source [message #44277 is a reply to message #43779] |
Wed, 08 June 2005 01:34  |
Great this works!
But the file was not there, I really had to copy it. Somehow it was'n
copie automatically.
Juergen
Gary Xue schrieb:
> The most likely cause is that the JDBC driver has not been installed in
> the viewer plugin directory. Check the following directory. Do you see
> your Oracle JDBC driver there? If not you will need to manually copy
> that driver's JAR files to this location for report preview to work:
> \eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0\birt\W EB-INF\plugins\org.eclipse.birt.report.data.oda.jdbc\drivers
> For more information about installing JDBC drivers, check the BIRT FAQ
> page. If this does not solve your problem, you should open a Bugzilla
> report so a BIRT developer can investigate.
> Gary Xue
> BIRT Committer - Data Engine project
FUDForum. Page generated in 0.06746 seconds
