Home » Archived » Visual Editor (VE) » Problems with JMenuItem in VE
Problems with JMenuItem in VE [message #3759] Fri, 21 November 2003 04:54 Go to next message
Originally posted by: roger.huesser.info
I've got a problem with adding a JMenuItem to a JMenu which is into a
JMenuBar, an this is into a JFrame. When i will drag the JMenuItem to
the JMenu it doesn't work. On my Mousearrow, it will display a forbidden
icon "ø". Can someone say me, what's not right?
Re: Problems with JMenuItem in VE [message #3794 is a reply to message #3759] Fri, 21 November 2003 09:05 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
Roger Huesser wrote:
> Hi
You will need to use the JavaBean Viewer to drop a JMenuItems.
Re: Problems with JMenuItem in VE [message #3800 is a reply to message #3794] Fri, 21 November 2003 09:32 Go to previous message
>> Hi
>> forbidden icon "ø". Can someone say me, what's not right?
Thank you it works!
Re: Problems with JMenuItem in VE [message #568026 is a reply to message #3759] Fri, 21 November 2003 09:05 Go to previous message
> Hi
Re: Problems with JMenuItem in VE [message #568058 is a reply to message #3794] Fri, 21 November 2003 09:32 Go to previous message
>> Hi
Thank you it works!
Previous Topic:Problems with JMenuItem in VE
Next Topic:Questions on the VE feature set
Current Time: Fri Nov 07 08:43:24 EST 2025
Powered by FUDForum. Page generated in 0.26325 seconds
