Home » Modeling » TMF (Xtext) » [Xtext] Problem : Cannot find compatible feature foo in sealed EClass
[Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43269] Thu, 07 May 2009 08:46 Go to next message
Originally posted by: sderrienREMOVE.irisa.fr
I want to define a DSL for an existing ecore meta model.
In this model I have an AbstractClass which has a feature named foo, and
a ConcreteClass that inherits from this AbstractClass.
I want to write a Rule to create an initialized instance of
ConcreteClass in which I initialize the feature foo (inherited from
AbstractClass).
I use the following Xtext Rule for this
MyRule1 returns ConcreteClass:
foo+=AnotherRule
However, I get the following error :
Cannot find compatible feature foo in sealed EClass ConcreteClass from
imported package http://mypackageURI.
Is there a way to specify that the feature belongs to the ParentClass
(something like super.foo+=AnotherRule) ? If not is there any alternive
solution ?
Steven Derrien
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43326 is a reply to message #43269] Thu, 07 May 2009 11:55 Go to previous messageGo to next message
Hey Steven,
> foo+=AnotherRule
the problem here is that Xtext tries to find a proper feature that
corresponds to "foo+=AnotherRule" in your meta model. Each assignment
has to match with respect to its name, cardinality and type.
Just looking at your snippet I would guess that AnotherRules does not
return the proper type for the given feature foo defined in your
existing meta model.
This should work:
MyRule returns ConcreteClass:
foo=AnotherRule;
AnotherRule returns TypeOfFeatureFooInConcreteClass:
some?="rule that matches return type";
Also, please be aware that "+=" and "=" expect different configurations
of your meta model. The former expects a multi value containment feature
where as the latter expect a single value containment.
Hope that helps,
Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43419 is a reply to message #43326] Thu, 07 May 2009 15:41 Go to previous messageGo to next message
Hello Heiko,
Thank you for your help.
Actually my example was not correct, since my DSL involves
cross-references. Here is the actual code snippet :
import "http://www.irisa.fr/cairn/datapath/fsm" as fsm
import "http://www.irisa.fr/cairn/datapath/port" as ports
FSMRule returns fsm::FSM :
ports+=InputPortRule terms+=PredicateTermRule;
InputPortRule returns ports::InControlPort:
name=ID;
PredicateTermRule returns fsm::PredicateTerm :
(negated?=('!'))? flag=[ports::InControlPort];
It is the flag feature that causes the error message :
"Cannot find compatible feature flag in sealed EClass PredicateTerm from
imported package http://www.irisa.fr/cairn/datapath/fsm."
In the ecore file defining the fsm package, the EClass *PredicateTerm*
has a EReference feature named *flag* of type *InControlPort*, with
upperBound set to 1, and containment set to false.
Unless I am missing something obvious, everything seems consistent
to me (I double-checked before writing this mail).
Do you have any hints ?
Thanks in advance,
Steven
Heiko Behrens a écrit :
> Hey Steven,
> This should work:
> foo=AnotherRule;
> Hope that helps,
> Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43512 is a reply to message #43419] Fri, 08 May 2009 02:37 Go to previous messageGo to next message
You use namespace URIs this implies that you have installed both
EPackages into the workbench. Did you?
We also need to have a look at the EPackages in order track the problem
down.
Sven
Steven Derrien schrieb:
> Hello Heiko,
> name=ID;
> Thanks in advance,
> Steven
>> Hey Steven,
>> This should work:
>> foo=AnotherRule;
>> configurations of your meta model. The former expects a multi value
>> containment feature where as the latter expect a single value
>> containment.
>> Hope that helps,
>> Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43662 is a reply to message #43512] Fri, 08 May 2009 05:54 Go to previous messageGo to next message
Hi Sven,
Yes, I can see them in the EMF package registry view. Anyhow, if
packages are not registered, the Xtext editor shows an error directly on
the corresponding *import* line.
> down.
I'll see If I can send them to you by mail.
Thanks for the support.
Steven
> Sven
>> Hello Heiko,
>> name=ID;
>> from imported package http://www.irisa.fr/cairn/datapath/fsm."
>> Thanks in advance,
>> Steven
>>> Hey Steven,
>>> This should work:
>>> foo=AnotherRule;
>>> containment.
>>> Hope that helps,
>>> Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #656376 is a reply to message #43662] Fri, 25 February 2011 06:19 Go to previous messageGo to next message
Hi gays,
I just jumped into the same issue and can't find any solution.
The problem is that I'm writing a FSM (FinitStateMachine) like DSL.
In the FSM, there is two type of nodes: controlNodes and simpleNodes.
I have an abstract node in my ecore which is an abstract super class for both nodes.
Both nodes have an id, so the id belongs to the AbstractNode and concrete node will inherit it.
The problem is, when I write some thing like :
ControlNode returns ControlNode:
 {ControlNode}
 	( 'ControlNode' id=EString
I got the runtime error :
 java.lang.IllegalArgumentException: ControlNode.id does not exist
So, How can I assign a value to the id when creating an instance for my concrete steps.
[Updated on: Fri, 25 February 2011 06:19] by Moderator
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #656396 is a reply to message #656376] Fri, 25 February 2011 07:47 Go to previous messageGo to next message
Hi Amine,
where do you get the runtime exception from? Does it occur when you
generate your language? Or when you edit your language files? In the
grammar editor?
Please make sure that your plugin.xml files are all up-to date (a quick
diff with the plugin.xml_gen will help).
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 25.02.11 12:19, schrieb Amine:
> Hi gays,
> The problem is that I'm writing a FSM (FinitStateMachine) like DSL. In
> the FSM, there is two type of nodes: controlNodes and simpleNodes. I
> both nodes. Both nodes have an id, so the id belongs to the AbstractNode
> {ControlNode}
> ( 'ControlNode' id=EString ...
> concrete steps.
> Thanks
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #656713 is a reply to message #656396] Mon, 28 February 2011 03:51 Go to previous messageGo to next message
Hi Sebastian,
Thank you for your response.
My error came when I try to edit my language files.
I think that it is not the way to assign a value to a feature that belongs to the superclass. I'm I wrong ?
Amine
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #656754 is a reply to message #656713] Mon, 28 February 2011 07:42 Go to previous messageGo to next message
The assignment should work for all (local and inherited) features.
How does your EString rule look like? Does it return a value that is
compatible to the type of the AbstractNode.id attribute? Do you define
the Ecore model yourself? Is it error free and registered correctly in
the plugin.xml?
Am 28.02.11 09:51, schrieb Amine:
> Hi Sebastian,
> Thank you for your response. My error came when I try to edit my
> language files.
> Thanks
> Amine
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #656759 is a reply to message #656754] Mon, 28 February 2011 08:11 Go to previous messageGo to next message
Jan Koehnlein wrote on Mon, 28 February 2011 07:42
My EString rule works for attributes owned by subclasses and the compatibility is fine. Here is its code:
EString returns ecore::EString:
	STRING | ID;
the plugin.xml?
Yes, I have an already defined Ecore and my xText editor is about to create models conform to my Ecore metamodel.
It's error free and registered correctly (since it works without the inheritance staff).
Amine
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #657047 is a reply to message #656759] Tue, 01 March 2011 07:53 Go to previous messageGo to next message
And what is the signature of the AbstractNode.id attribute?
Am 28.02.11 14:11, schrieb Amine:
> STRING | ID;
> Quote:
>> the plugin.xml?
> create models conform to my Ecore metamodel. It's error free and
> Amine
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #657049 is a reply to message #657047] Tue, 01 March 2011 08:14 Go to previous messageGo to next message
The AbstractNode.id attribute is an EString too.
 {ControlNode}
 	( 'ControlNode' id=EString ':'
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #657152 is a reply to message #657049] Tue, 01 March 2011 12:35 Go to previous messageGo to next message
Hi Amine,
I guess Jan meant the signature of the actual EClass / Java class, e.g.
something like
public String getId() { .. }
in AbstractNode.java.
Please provide this snippet as well.
Sebastian
Am 01.03.11 14:14, schrieb Amine:
> {ControlNode}
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #657330 is a reply to message #657152] Wed, 02 March 2011 08:27 Go to previous messageGo to next message
Problem solved, I just changed the name of the attribute from "id" to "name" and it works !!! Shocked
I don't have any explanation to this. I also tried to do the reverse thing for other attributes that was used to identify the objects from "name" to "id" and had the same issue !!!
Is this probably a bug ? or am I just doing something wrong.
Many thanks
Amine
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #657333 is a reply to message #657330] Wed, 02 March 2011 08:35 Go to previous messageGo to next message
Xtext references work (by default) though a feature (attribute) called "name". You can change this by using a own IQualifiedNameProvider
So this works out of the box:
ThingIWantToReference:
 "thing" name=ID;
Reference:
  "ref" thing=[ThingIWantToReference];
and this with a changed NameProvider
 "thing" afeature=ID;
Reference:
~Christian
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #671499 is a reply to message #43269] Wed, 18 May 2011 02:50 Go to previous message
I just found the following while googling for the same problem, posting it here so that others don't have to:
Check your model containment attributes.
I had an ecore model containing a multi-valued reference to another class, but forgot to set the containment flag on the reference. The result was the "incompatible feature" error.
Check this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=316610
Hope this helps.
Previous Topic:Help with dot operator implementation
Next Topic:White Spaces into keywords of Xtext grammar
Current Time: Wed Nov 19 03:38:35 EST 2025
Powered by FUDForum. Page generated in 0.32539 seconds
