| update manager hinders RCP-based application [message #43138] |
Wed, 09 June 2004 16:14  |
Using 3RC1 with JDK 1.4 on W2K
I have a simple RCP-based application that works fine. After adding a
dependency in plugin.xml to org.eclipse.update.ui, my application is not
found any more like reported below:
eclipse.buildId=unknown
java.version=1.4.2_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -application rcpdemo.rcpdemoapp
!ENTRY org.eclipse.osgi Jun 08, 2004 23:45:36.341
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "rcpdemo.rcpdemoapp" could not
be found in the registry. The applications available are:
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.update.core.standaloneUpdate.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:324)
Somehow the update manager seems to prevent my application from being
added to the application registry. Any ideas?
Chris
FUDForum. Page generated in 0.04296 seconds
