Home » Newcomers » Newcomers » Eclipse error at startup.
Eclipse error at startup. [message #43133] Tue, 29 March 2005 14:18 Go to next message
Originally posted by: thomasw.nork.auc.dk
When I try to start Eclipse I get following error ( in the log file) see
below:
I am Using Eclipse 3.02 on a Linux(Debian) platform.
I had an error before from a eclipse 3.0 version. I removed the
directories:eclipse and workspace, downloaded the file
eclipse-SDK-3.0.2-linux-gtk.zip and undpacked. Now when i try to launch
the eclipse(executable) file a get an error.
Can anyone help me ?
// Thomas W
SESSION Mar 29, 2005 21:15:28.418
eclipse.buildId=M200503110845
java.version=1.4.1
java.vendor=Blackdown Java-Linux Team
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Mar 29, 2005 21:15:28.421
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.FontData.setHeight(FontData.java:29 6)
at org.eclipse.swt.graphics.FontData.<init>(FontData.java:168)
at org.eclipse.swt.graphics.Font.getFontData(Font.java:197)
org.eclipse.jface.resource.FontRegistry.calculateDefaultFont (FontRegistry.java:412)
org.eclipse.jface.resource.FontRegistry.defaultFontRecord(Fo ntRegistry.java:430)
org.eclipse.jface.resource.FontRegistry.getFontRecord(FontRe gistry.java:519)
at org.eclipse.jface.resource.FontRegistry.get(FontRegistry.jav a:472)
org.eclipse.jface.resource.JFaceResources.getDialogFont(JFac eResources.java:182)
at org.eclipse.jface.dialogs.Dialog.initializeDialogUnits(Dialo g.java:778)
org.eclipse.jface.dialogs.TitleAreaDialog.createContents(Tit leAreaDialog.java:93)
at org.eclipse.jface.window.Window.create(Window.java:348)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:925)
at org.eclipse.jface.window.Window.open(Window.java:637)
org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Cho oseWorkspaceDialog.java:65)
org.eclipse.ui.internal.ide.IDEApplication.promptForWorkspac e(IDEApplication.java:314)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:219)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:83)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Eclipse error at startup. [message #43213 is a reply to message #43133] Tue, 29 March 2005 22:51 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Thomas,
Try running Eclipse with a Sun or IBM JRE. The error you're getting is
probably occurring because you're launching with Blackdown java which
may be incompatible.
Hope this helps,
- Jeff
> below:
> // Thomas W
> java.version=1.4.1
Re: Eclipse error at startup. [message #43324 is a reply to message #43213] Wed, 30 March 2005 06:24 Go to previous message
Hi Jeff
I wil try that. But I have been using Eclipse version 3.0 for a half a
year without problems.
RGDS
Thomas W
Jeff Myers wrote:
> Thomas,
> Hope this helps,
> - Jeff
>> see below:
>> launch the eclipse(executable) file a get an error.
>> // Thomas W
>> java.version=1.4.1
Previous Topic:Opening a cheatsheet from help
Next Topic:Language pack not found wXP
Current Time: Wed Nov 05 12:25:43 EST 2025
Powered by FUDForum. Page generated in 0.08601 seconds
