Home » Eclipse Projects » Remote Application Platform (RAP) » IE vs Firefox performance
| IE vs Firefox performance [message #43076] |
Thu, 23 August 2007 05:56  |
My team is planing a RAP based solution and one thing I noticed while
evaluating RAP is that performance is worst on IE (7 in this case). This is
mostly noticeable with the progressbar widget, where the progress takes a
lot longer to complete in IE using the exact same code.
My question is: is this due to IE js implementation or are there any
optimizations possible.
This is somewhat important for our solution as our primary target platform
is Windows/IE7.
Thanks.
Tiago
| Re: IE vs Firefox performance [message #43775 is a reply to message #43605] |
Wed, 29 August 2007 03:46   |
Originally posted by: rherrmann.innoopract.com
Roberto,
we currently focus on IE 7 performance. IE 6 will surely benefit
thereof, but at least until 1.0 (due 2007-09-28) we won't have time to
pay special attention on IE 6.
If you want to give it a try, you can check out the latest from CVS. We
checked in the changes yesterday.
Rüdiger
Roberto Sánchez wrote:
> Hi Rüdiger, My application runs well (more or less) in Firefox 2.x and
> IE 7 (A bit faster in Firefox) but in IExplorer 6 goes so slowly that
> It's impossible to work with it.
> Are you working to improve IE6 performance or only in IE7 ?
> Regards.
> Roberto.
> Rüdiger Herrmann escribió:
>> Hi Tiago,
>> we are aware of this problem and currently working on it. From what we
>> know it is due to the IE JavaScript implementation. We already gained
>> some performance improvements (not yet in CVS) but hope to further
>> improve the situation.
>> If you have any input on what could improve the JavaScript performance
>> on IE, feel free to share.
>> Cheers,
>> Rüdiger
>> Tiago wrote:
>>> Hi,
>>> This is mostly noticeable with the progressbar widget, where the
>>> progress takes a lot longer to complete in IE using the exact same code.
>>> platform is Windows/IE7.
>>> Thanks.
>>> Tiago
| Re: IE vs Firefox performance [message #43838 is a reply to message #43775] |
Wed, 29 August 2007 04:25   |
Hi Rüdiger, I've updated with CVS latest version and I've found 2 problems:
In IE 7 appears 2 Javascript errors when index.html is loaded, I have a
Login dialog that isn't shown.
Line: 1588
Character: 3
Error: It was espected a variable, string or number (Original message in
Spanish: Se esperaba un identificador, una cadena o un número)
Line: 12808
Character: 9
Error: 'org' is not defined.
In Firefox (under Mac OS) all works fine, there is no errors, but there
is a problem with TreeItems (I don't know if it is related with this,
but yesterday there was no problem), The problem is that the item text
size is too short and It can't be shown correctly, I've tested RAP demo
app and the problem appears here too.
I'll create a bug ASAP.
Regards.
Roberto
> Roberto,
> Cheers,
> Rüdiger
>> Regards.
>> Roberto.
>>> Hi Tiago,
>>> we know it is due to the IE JavaScript implementation. We already
>>> gained some performance improvements (not yet in CVS) but hope to
>>> further improve the situation.
>>> performance on IE, feel free to share.
>>> Cheers,
>>> Rüdiger
>>> Tiago wrote:
>>>> Hi,
>>>> while evaluating RAP is that performance is worst on IE (7 in this
>>>> case). This is mostly noticeable with the progressbar widget, where
>>>> the progress takes a lot longer to complete in IE using the exact
>>>> same code.
>>>> Thanks.
>>>> Tiago
| Re: IE vs Firefox performance [message #43871 is a reply to message #43838] |
Wed, 29 August 2007 04:50   |
I've created 2 bugs entries:
For javascript problem in IE7:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201532
For tree item issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=201531
Both problems can be reproduced in RAP demo app.
Regards.
Roberto.
> Line: 1588
> Character: 3
> Line: 12808
> Character: 9
> Regards.
> Roberto
>> Roberto,
>> We checked in the changes yesterday.
>> Cheers,
>> Rüdiger
>>> and IE 7 (A bit faster in Firefox) but in IExplorer 6 goes so slowly
>>> that It's impossible to work with it.
>>> Regards.
>>> Roberto.
>>>> Hi Tiago,
>>>> Cheers,
>>>> Rüdiger
>>>> Tiago wrote:
>>>>> Hi,
>>>>> same code.
>>>>> any optimizations possible.
>>>>> Thanks.
>>>>> Tiago
| Re: IE vs Firefox performance [message #52018 is a reply to message #51939] |
Tue, 16 October 2007 14:50  |
Originally posted by: jkrause.innoopract.com
Performance is much better now with IE7, but there is still room for
improvement. The qooxdoo team is also working on improving performance,
both startup and rendering. But even with a fully optimized RAP and
qooxdoo IE6 will remain a mediocre execution environment for Ajax apps.
Jochen
T.Gau wrote:
> Now, where version 1.0 is out I like to ask whether this performance
> issue under IE6/7 has been solved?
> Regards, T.Gau
> Rüdiger Herrmann schrieb:
>> Roberto,
>> Cheers,
>> Rüdiger
Current Time: Wed Nov 05 06:49:12 EST 2025
Powered by FUDForum. Page generated in 0.06075 seconds
