| New stable build of IHE and Bridge components now available [message #43031] |
Thu, 01 May 2008 14:32  |
Greetings,
We are pleased to announce a new major build of the Eclipse OHF IHE and
Bridge components is now available. This build reflects stable code tested
and validated by multiple vendors at the 2008 IHE North American and
European Connectathons.
About the Build
The new build is numbered 0.3.0 Milestone 1. This build reflects
substantial changes over the 0.2.x builds, conforms to the 2007-2008 IHE
ITI Technical Framework, and was tested by multiple vendors at the 2008 IHE
Connectathons. All major bugs are now closed and any outstanding issues
are deemed minor.
IHE updates include:
* Updates to all existing IHE profile implementations for 2007-2008,
including all relevant CPs
* Added support for IHE XDS.b Document Source and Document Consumer,
* Added support for IHE XCA - Cross Community Access
* Added support for IHE PDVQ - Patient Demographic Visit Query
Bridge updates include:
* Updates for API changes to the IHE components
* Separation of configuration manager into separate component
Specifically this build implements the following IHE profiles, actors, and
transactions:
Audit Trail and Node Authentication (ATNA) - Secure Node and Secure
Application
* ITI-19: Authenticate Node
* ITI-20: Record Audit Message
Patient Demographic Query (PDQ) - Patient Demographics Consumer
* ITI-21: Patient Demographics Query
* ITI-22: Patient Demographics and Visit Query
Patient Identity Cross-Referencing (PIX) - Patient Identity Source and PIX
Consumer
* ITI-8: PIX Feed
* ITI-9: PIX Query
Cross-Enterprise Document Sharing A (XDS.a) - Document Source and Document
Consumer
* ITI-15: Provide and Register Document Set
* ITI-16: Query Registry
* ITI-17: Retrieve Document
* ITI-18: Registry Stored Query
Cross-Enterprise Document Sharing B (XDS.b) - Document Source and Document
Consumer
* ITI-18: Registry Stored Query (w/XDS.b semantics)
* ITI-41: Provide and Register Document Set-b
* ITI-43: Retrieve Document Set
Cross Community Access (XCA)
(no actors implemented, but supported through XDS)
With this release, we are discontinuing interim / daily builds that were
kept for Connectathon users. Please use the stable builds if you wish to
use the IHE or Bridge components. If you are interested in using OHF with
legacy IHE infrastructure (2006-2007), please use build 0.2.0.
Downloads
For binary downloads of the 0.3.0 versions, please see the official OHF
Downloads page:
http://www.eclipse.org/ohf/downloads/
Help and Support
For questions and support with OHF, we encourage the use of the newsgroup.
For more information:
http://www.eclipse.org/ohf/newsgroup.php.
To submit bugs, please use the Eclipse Bugzilla site. See:
http://www.eclipse.org/ohf/bugs.php.
-Matt Davis
IBM Almaden Research Center
| Re: New stable build of IHE and Bridge components now available [message #43549 is a reply to message #43418] |
Tue, 08 July 2008 17:05  |
Hi Werner,
I don't completely follow your issue here ... did you not even get a
stack trace you could give us from Tomcat?
- Sarah
Werner Keil wrote:
> That is where it failed.
> Unfortunately the client where this was used to demonstrate custom
> Exception Handling and usage of Log4J has no clue of what to log and how
> Therefore the demonstration does not exist any more. And they keep
> chatting until the end of time (or till their budget runs out)
> Matthew Davis wrote:
>> Hi Werner,
>> Could you post a log file of the errors? We primarily have tested
>> them in Windows, but it should work on both Windows and Linux.
>> Thanks
>> -Matt
>> Werner Keil wrote:
>>> Hi,
>>> I tried both the 0.3.0 Milestone and the earlier released 0.2.x build
>>> (the download packages) and both equally fail on Windows in the
>>> described environment:
>>> Tomcat 5.x
>>> Java 5
>>> Is this known to work on Windows, or has it mostly been used on Unix
>>> systems only?
>>> Thanks,
>>> Werner
| Re: New stable build of IHE and Bridge components now available [message #585714 is a reply to message #43361] |
Sat, 05 July 2008 00:01  |
Hi Werner,
Could you post a log file of the errors? We primarily have tested them
-Matt
Werner Keil wrote:
> Tomcat 5.x
> Java 5
> systems only?
> Werner
| Re: New stable build of IHE and Bridge components now available [message #585727 is a reply to message #43386] |
Sat, 05 July 2008 09:57  |
Exception Handling and usage of Log4J has no clue of what to log and how ;-/
> Hi Werner,
> Thanks
> -Matt
> Werner Keil wrote:
>> Tomcat 5.x
>> Java 5
>> systems only?
>> Thanks,
>> Werner
| Re: New stable build of IHE and Bridge components now available [message #585776 is a reply to message #43418] |
Hi Werner,
- Sarah
>> Hi Werner,
>> Thanks
>> -Matt
>> Werner Keil wrote:
>>> Hi,
>>> Tomcat 5.x
>>> Java 5
>>> systems only?
>>> Thanks,
>>> Werner
FUDForum. Page generated in 0.07043 seconds
