| Re: Referencing attribute of target class in message of OCL Constraint [message #42967] |
Tue, 06 November 2007 07:24  |
Lars,
I'm not sure how the OCL constraints produce messages. Christian will
have good ideas. I've included the OCL newsgroup in the "to" list of
the reply...
Lars Heinemann wrote:
> do you know if it is possible to use the value of a String attribute
> of the target object in the error message in an OCL constraint? E.g. I
> would like to include the name of the model object in the failure
> message.
> Cheers,
> Lars
| Re: Referencing attribute of target class in message of OCL Constraint [message #42999 is a reply to message #42967] |
Tue, 06 November 2007 09:38  |
Hi, Ed, Lars,
Actually, this isn't an MDT OCL question, but an
org.eclipse.emf.validation.ocl question.
Currently, the OCL constraint provider only supports substituting the {0}
message parameter with the label of the problem object.
It would be nice for clients to be able to define, perhaps via the
name/value parameters supported by the IParameterizedConstraintDescriptor,
OCL expressions that compute the string to substitute into a given {n} slot
in the message.
Sounds like a good contribution with which to get to know how the EMF
Validation Framework component works!
Ed Merks wrote:
> Lars,
> the reply...
>> message.
>> Cheers,
>> Lars
FUDForum. Page generated in 0.04033 seconds
