Home » Eclipse Projects » Eclipse Platform » Eclipse built-in CVS and TortoiseCVS again
Eclipse built-in CVS and TortoiseCVS again [message #42869] Wed, 21 May 2003 16:10 Go to next message
Hi!
I've brought this up earlier. If I Checkout a Project from Eclipse (Java IDE)
and then try to perform cvs commands from outside using Tortoise I get the "This
CVS sandbox may be for Unix, not Windows" error dialog message.
I can of course disable this check in the TortoiseCVS - is this safe?
Or is there another way - e.g. can I configure Eclipse to use Windows style line
endings?
Jimisola
Re: Eclipse built-in CVS and TortoiseCVS again [message #45486 is a reply to message #42869] Fri, 23 May 2003 09:21 Go to previous message
Originally posted by: Michael_Valenta.oti.com
Eclipse does use Unix line endings in the Entries file and does not
provide a means of changing this. I have raised a bug report for this
issue (https://bugs.eclipse.org/bugs/show_bug.cgi?id=38035). As for
TortoiseCVS, I suspect that the setting is safe to disable but I don't
know for sure.
Michael
Jimisola Laursen wrote:
> Hi!
> endings?
> Jimisola
Previous Topic:WizardPage Refresh
Next Topic:What's going on when saving?
Current Time: Fri Nov 14 20:13:59 EST 2025
Powered by FUDForum. Page generated in 0.03984 seconds
