Home » Archived » Visual Editor (VE) » No option to create a Visual Class
| No option to create a Visual Class [message #42861] |
Mon, 21 June 2004 17:49  |
Originally posted by: chi.topvu.com
I am new to Eclipse and the Visual Editor and tried to create my first
example. However, there is no option for Visual Class in the Package
Explorer. The following versions of the plugins are installed:
VE-runtime-I20040617.zip
GEF-runtime-I20040617.zip
emf-sdo-runtime-I200406171028.zip
The .log in the .metadata directory shows some error related to Ant. They
are below:
!SESSION Jun 21, 2004
16:43:13.634 ---------------------------------------------
eclipse.buildId=I200406111814
java.version=1.4.2_04
!ENTRY org.eclipse.osgi Jun 21, 2004 16:43:13.634
!MESSAGE Error while stopping "org.eclipse.ant.core_3.0.0".
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.stop () of bundle
org.eclipse.ant.core.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContex
tImpl.java:1010)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.ja
va:502)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.
java:437)
org.eclipse.core.runtime.adaptor.BundleStopper.stopBundles(B undleStopper.jav
a:67)
a:54)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAda
ptor.java:549)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:4
52)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.jav
a:182)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
org.eclipse.debug.internal.core.EnvironmentVariableResolver. resolveValue(Env
ironmentVariableResolver.java:37)
org.eclipse.core.internal.variables.DynamicVariable.getValue (DynamicVariable
..java:54)
org.eclipse.ant.core.AntCorePreferences.getToolsJarEntry(Ant CorePreferences.
java:650)
org.eclipse.ant.core.AntCorePreferences.updateAdditionalEntr ies(AntCorePrefe
rences.java:1330)
org.eclipse.ant.core.AntCorePreferences.updatePluginPreferen ces(AntCorePrefe
rences.java:1249)
at org.eclipse.ant.core.AntCorePlugin.shutdown(AntCorePlugin.ja va:169)
org.eclipse.core.internal.compatibility.PluginActivator.stop (PluginActivator
..java:74)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleConte
xtImpl.java:994)
tImpl.java:990)
... 8 more
Root exception:
..java:54)
java:650)
rences.java:1330)
rences.java:1249)
..java:74)
xtImpl.java:994)
tImpl.java:990)
va:502)
java:437)
a:67)
a:54)
ptor.java:549)
52)
a:182)
| Re: No option to create a Visual Class [message #42924 is a reply to message #42861] |
Mon, 21 June 2004 19:35   |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
There is no option for visual class in package explorer. You open a
class using Open With->Visual Editor. It is another kind of editor on a
java class.
However, one thing, the 6/17 drop of VE uses the 6/17 drop of Eclipse,
not the 6/11 drop. It is possible that it may work, but it wasn't tested
on 6/11.
> are below:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #43025 is a reply to message #42924] |
Tue, 22 June 2004 10:09   |
From where can the Visual Editor be accessed? In Package Explorer, I
highlighted the class, right click and chose Open With. The listed choices
are: Java Editor, Text Editor, System Editor, In Place Editor and Default
Editor. Is this not the right place or does it mean it's not working and I
need the 6/17 drop of Eclipse?
Chi
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cb7raq$jgd$1@eclipse.org...
> java class.
> on 6/11.
They
> > are below:
> Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #43632 is a reply to message #42924] |
Wed, 23 June 2004 17:53   |
Rich:
I'm having also unable to create a visual class within Eclipse 3.0RC3.
I've the same problem with the lastest stable releases on Eclipse and
VE. I installed VE by just copying unziped file to Eclipse directory. I
could not find anything to 'turn on' in Customize Perspective or
Preferences. I double checked the Product Configuration VE appears to
enable and properly configured.
Yet, I am unable to create Visual Class in the Java Perspective. I also
tried to create a class and then use the "Open with..." menu. In both
cases, there was no method to create Visual Class.
I am running the following.
* Eclipse 3.0RC3 Sat, 19 Jun 2004 -- 20:00 (-0400)
* VE-runtime-S20040622
* EMF build I200406221136
* GEF Build I20040619
I have deleted my .metadata and configure directories, still no luck. I
also tried using a new workspace, no luck.
Here is my .log file.
!SESSION Jun 23, 2004 17:37:57.593
eclipse.buildId=unknown
java.version=1.4.2_02
!ENTRY org.eclipse.ui 4 4 Jun 23, 2004 17:37:57.593
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Jun 23, 2004 17:37:57.593
!MESSAGE Argument not valid
!STACK 0
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.Image.init(Image.java:1351)
at org.eclipse.swt.graphics.Image.<init>(Image.java:161)
at org.eclipse.ui.forms.widgets.FormText.paint(FormText.java:77 8)
at org.eclipse.ui.forms.widgets.FormText.access$3(FormText.java :762)
at org.eclipse.ui.forms.widgets.FormText$2.paintControl(FormTex t.java:226)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:82)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:80 3)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3020 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3298 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 67)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2396)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1375)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1346)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:252)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
at org.eclipse.core.launcher.Main.basicRun(Main.java:186)
at org.eclipse.core.launcher.Main.run(Main.java:647)
at org.eclipse.core.launcher.Main.main(Main.java:631)
| Re: No option to create a Visual Class [message #50995 is a reply to message #50829] |
Mon, 19 July 2004 14:52  |
Originally posted by: timnesham.msn.com
Right. I had an existing workspace I use for work-related development. I
then unzipped all the files into the preexisting 3.0 workspace. No big
deal as long as I can access the Visual Editor in some way.
So far the quality seems very high for a 1.0 version. Keep it up!
| Re: No option to create a Visual Class [message #592280 is a reply to message #42861] |
java class.
on 6/11.
> are below:
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #592313 is a reply to message #42924] |
Chi
> java class.
> on 6/11.
They
> > are below:
> Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #592326 is a reply to message #43025] |
Tue, 22 June 2004 10:28  |
That is correct. It means that VE is not installed correctly.
First, try erasing the configuration directory in the eclipse
installation directory. It may be that it is not seeing the new plugins.
If that fails, try to use the Stable build that was just released on
yesterday (Monday S20040621) with the corresponding Eclipse, GEF, and
EMF that are listed there.
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #592370 is a reply to message #43057] |
Tue, 22 June 2004 14:41  |
Wiping out the Configuration directory and restarting Elcipse did it! I now
have access to the Visual Editor. Very nice tool!
Thanks for you help,
Chi
news:cb9fmj$qch$1@eclipse.org...
> Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #592560 is a reply to message #42924] |
Rich:
!STACK 0
| Re: No option to create a Visual Class [message #592582 is a reply to message #43632] |
Wed, 23 June 2004 18:20  |
That doesn't sound like it is installed correctly. You said you copied
the unzipped files to the eclipse directory. The unzipped files have
eclipse as their root, so you should instead unzip GEF, EMF, and VE into
the directory above eclipse, i.e.
d:/mystuff/eclipse
you would unzip into mystuff, not into eclipse.
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #592650 is a reply to message #43694] |
Thu, 24 June 2004 16:06  |
> d:/mystuff/eclipse
This isn't the problem Rich. I unzip files into a working directory then
draged the Eclipse folder to my C: drive, so the Windows would
automaticly copy the files into the correct directories under 'c:\eclipse'
If it is not be installed correctly, why is it enabled in Product
Configuration and the status is ' configured properly.' I'd drop back to
previous build, but I don't think they work with Eclipse 3.0. When is
the next stable build planned?
Jeff Duska
| Re: No option to create a Visual Class [message #592675 is a reply to message #43877] |
Thu, 24 June 2004 18:08  |
I haven't a clue what is going on. Nobody has had a case where it shows
it is installed correctly, there are no errors in the .log, but yet
Open as->Visual Editor
doesn't show up on the popup menu of a java source class (i.e. not a
..class file)?
Another stable build came out today, but it is basically no different
than earlier this week. You can try it, but I still think it is
something about the way it is installed.
Just to humor me, create a new directory, and just unzip all of the zips
to that directory. Then run eclipse from there instead of from the
directory under the root as you now have it. Most people don't have
eclipse in their root directory, they usually have it under some other
directory. Use a new workspace too.
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #595425 is a reply to message #43934] |
Sat, 17 July 2004 11:29  |
This happened to me. After I deleted the configuration directory the
Visual Class item did not appear. But, after opening the "other" item
*and* navigating through the Java folder item, it was hidden in there.
How can I get it to "come up" to the right-mouse click menu?
| Re: No option to create a Visual Class [message #595461 is a reply to message #50743] |
Mon, 19 July 2004 09:58  |
Where you in an existing workspace and had modified the perspective in
some way, such as adding a view? If you had, Eclipse doesn't further
update the perspective by adding in new things automatically. It leaves
it the way you had modified it.
Thanks, Rich Kulp
| Re: No option to create a Visual Class [message #595500 is a reply to message #50829] |
Current Time: Wed Nov 12 03:27:35 EST 2025
Powered by FUDForum. Page generated in 0.06906 seconds
