Home » Eclipse Projects » Plugin Development Environment (PDE) » Circular Dependency Problem
Circular Dependency Problem [message #42843] Wed, 28 January 2009 05:35
Hi All;
I am new in Eclipse Plug-in development. I have a main plug-in project
named "Runner" which runs on both Eclipse version 3.2 & 3.4 very well.
Now I have created a another plug-in named "Uml2Diagram" to support the
functionality of UML2 tools diagram in "Runner" plug-in for Eclipse 3.4
and a empty plug-in "Uml2Diagram" for Eclipse 3.2, since UML2 tools is
available only in 3.4.
The both "Uml2Diagram" plug-in (for 3.4 & 3.2) dependent on "Runner"
plug-in (due to referring some model classes of "Runner" plug-in) and also
"Runner" plug-in is optional dependent on both "Uml2Diagram" sub plug-in
due to load the classes at run time.
While debugging in 3.4 & 3.2, functionality is proper but while exporting
it as a "plug-ins and fragments". Eclipse generates Circular Dependency
Problem and terminates.
Please tell how can I fix my problem or remove Circular Dependency
Problem, so that same plug-in can run in 3.4 & 3.2.
Thanks in Advance
Kishore
Previous Topic:What is the preferred/correct way to build a complex eclipse product?
Next Topic:Circular Dependency Problem
Current Time: Fri Nov 07 01:44:09 EST 2025
Powered by FUDForum. Page generated in 0.02743 seconds
