Home » Eclipse Projects » Remote Application Platform (RAP) » Discouraged access warning
Discouraged access warning [message #42818] Wed, 22 August 2007 07:07 Go to next message
Hi all, when I updated at M6 It Appeared a new warning in the
application:
"Discouraged access: The type ContextProvider is not accessible due to
restriction on required project org.eclipse.rap.rwt"
I can see it in theses objects:
URLHelper, ContextProvider, Event, etc.
But the application seems to work fine.
Can anyone tell what is that, Have I to do anything about ?
Thanks.
Roberto.
Re: Discouraged access warning [message #42880 is a reply to message #42818] Wed, 22 August 2007 09:18 Go to previous messageGo to next message
Originally posted by: b.muskalla.gmx.net
Hi Roberto,
Discouraged access warning means that you use something from an
*.internal package. This means for you that the classes/methods you're
using are *not* officially supported API and can be changed whenever we
think that we need to change them. Eclipse warns you that you should not
rely on internal things.
I'm just interested: For what do you use the ContextProvider? Any
interesting use case?
Greets
Benny
> application:
> Thanks.
> Roberto.
Re: Discouraged access warning [message #42941 is a reply to message #42880] Wed, 22 August 2007 11:20 Go to previous messageGo to next message
Hi Benny, I use:
- ContextProvider to get application url parameters.
- URLHelper to get the url of the application.
- Event#getSource() to get the object when the event has happened.
I got this warning in those cases. Is there any alternative way to do that ?
Regars.
Roberto.
Benjamin Muskalla escribió:
> Hi Roberto,
> Greets
> Benny
>> application:
>> Thanks.
>> Roberto.
Re: Discouraged access warning [message #43257 is a reply to message #42941] Sat, 25 August 2007 07:24 Go to previous messageGo to next message
Hi again, I've replaced:
- ContextProvider.getRequest() by RWT.getRequest()
- ContextProvider.getRequest().getSession() by RWT.getSessionStore()
Now I'm using ISessionStore in my RAP Application.
- event.getSource() by event.widget
But I don't know how to replace: URLHelper.getURLString(false) I need
the system url to call other servlets of my application
Thanks in advance.
Roberto.
Roberto Sá‡nchez escribió:
> Hi Benny, I use:
> that ?
> Regars.
> Roberto.
>> Hi Roberto,
>> we think that we need to change them. Eclipse warns you that you
>> should not rely on internal things.
>> Greets
>> Benny
>>> application:
>>> to restriction on required project org.eclipse.rap.rwt"
>>> Thanks.
>>> Roberto.
Re: Discouraged access warning [message #43302 is a reply to message #43257] Mon, 27 August 2007 04:57 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Roberto,
please see my comments below.
Rüdiger
Thanks for the hint. Calling event.getSource() should be possible
without a warning.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=201225
It looks like you have to live with this for some time. I fully
understand your use-case but unfortunately I don't see a possibility to
provide API therefore until 1.0.
> Thanks in advance.
> Roberto.
>> Hi Benny, I use:
>> that ?
>> Regars.
>> Roberto.
>>> Hi Roberto,
>>> you're using are *not* officially supported API and can be changed
>>> whenever we think that we need to change them. Eclipse warns you that
>>> you should not rely on internal things.
>>> Greets
>>> Benny
>>>> application:
>>>> Thanks.
>>>> Roberto.
Re: Discouraged access warning [message #48232 is a reply to message #43302] Wed, 19 September 2007 09:31 Go to previous messageGo to next message
How can I replace the following line to avoid warnings:
ContextProvider.getStateInfo().getResponseWriter()
I need this within my PhaseListeners.
RWT.getResponse().getWriter() seems to return a different object (and causes
an exception later on).
Stefan.
"R
Re: Discouraged access warning [message #49044 is a reply to message #48232] Sun, 23 September 2007 05:12 Go to previous message
Originally posted by: fappel.innoopract.com
the HtmlResponseWriter is a leftover of the old W4Toolkit library. It isn't
public API, since it may be replaced in the future completely. So what are
you using this class for - maybe there is another solution. The
RWT.getResponse().getWriter() cannot be used at the moment, since this
writes output directly into the stream, in contrast to HtmlResponseWriter
which does a buffering - one of the reasons I want to get rid of it on the
long run...
Ciao
Frank
"Stefan R
Previous Topic:big images in Tree
Next Topic:"URI too large" warning
Current Time: Fri Nov 07 21:57:23 EST 2025
Powered by FUDForum. Page generated in 0.03513 seconds
